DIY: Interior LED swap (cluster, HVAC, switches, window, *steering wheel)
god i wanna do what chubone did but first of all im too afraid to and prob have lack of skills to do it. everyones have turnedout killerthough. what was toyota thinking to go orange? reallly
wow that shit is the tightest one i have seen.... you wanna do mine? haha
Ha ha thanks man, it's really not all that hard once you get started. This thread is the ish! It helped 100% and if you follow the thread you'll see that Darkie has responded to everyone and that helps A TON!! Good lookin out Darkie.
1k should be fine. it think that's the lowest you can go without eventually blowing the LEDs.
Word! Thanks dude, yeah I had really no idea on the resistors. BTW do you kno what bulbs are in the cup holders an the gear box? And the arrows for the HVAC, are they the same as the gauges?
still haha... i think id rather pay someone to do it and do it right then me try
Is there a place to get these already made HVAC LEDs?
you can try Superbrightleds.com. here is a link directly to the neowedge style LED's.
I want to say i tried something like this initially, but they wouldn't fit because the piece that holds the LED (shaft?) is a larger diameter than stock. i could be wrong but just want to call it out for you. I never used a caliper to measure the difference but it might be worth doing before ordering them.
as another FYI for others considering to do this, if these do work you can only use them for the HVAC where the light is directly above the LED. You don't want to use these for the switches since not aiming the LEDs towards the button itself will leave them very dim.
K so I did the HVAC and everything is SUPER dim.. Any ideas on why? Could it be the resistors? I used 1k instead of 1.2k..
well going with 1k instead of 1.2k actually means you're allowing more power to the LED. are you talking about the display or the entire HVAC unit (selectors and buttons)?
I'm going to assume you're using Blue LED's to match your cluster. what is the voltage across the LED? I know the white LED's is 3.0-3.2V.
Also i just saw your earlier question about the arrows. the arrows are the same as the LED's you're using for the bulb holders and switches. I haven't gotten around to replace those yet but they will need a resistor on those too.
I like the look of the white but I am in the process of moving to Florida so it may have to wait for later. What I would like to do is fix the amber backlight in the center LCD cluster display (the one directly below the stereo) and above the climate controls. I pulled it out when I added a VAIStech adapter for my iPod and I think I either broke/damaged the current bulb.
The numbers (i.e. temperature/mpg/avg speed) in black are still fine but the drivers side half of the panel no longer has an amber backlight.
What part do I need/is this an easy fix (assuming I just want to replace it to get it looking like stock?
I already tried removing the panel and reinstalling the connector to see if I somehow didn't have the contacts touching but no go.
Thanks in advance for the help.
It could be as simple as the bulb going out. i think the entire part (bulb and bulb holder) is around $7. just buy and replace. not sure of the part number but just pull it out and replace it with a working one to make sure that is what causing the issue.
Hi quick question can someone post pictures or write how to replace bulb that lights up gear letters (P,R,N,D,....) but those where the shift knob is not on the cluster thnx
$6.32 and about 5 minutes fixed the problem. Just be careful as there are two different styles of bulbs in that cluster.
i just did my HVAC lights along with the climate LCD.
my problem is that i'm getting an uneven light output for the three HVAC (Fan/Temp/Position) buttons. it seems like the bottom left corner is the brightest and the other parts are dim. i've tried pointing the LED towards the center a bit, but it seems like Darkie didn't angle them at all. i'm talking about the long skinny bulb holders.
any reason why this is or how i can fix it? thanks guys :sadwave:
