Jakeepoo3
Yes, this non-start thing had only happened 3 or 4 times before, where I'd turn the key and nothing. I'd immediately take the key out and try again, and it would fire up then... until last week (or the week before), where every time I tried to start it it wouldn't turn over. So, reading some threads I tested the starter relay. It seemed to work, as I had continuity on pins 1 and 2, and no continuity on any other combination of 2 pins. Then I connected some test leads to pins 1 and 2, and the other end of the leads on the battery. Once I touched the leads on the battery I heard the relay click, and now putting my meter on pins 3 and 5 I had power. So I thought the relay is good. I put it back in and still couldn't get it to turn over. I took the relay out again and put a jumper on the receptacle for pins 3 and 5 and it immediately turned over. I pulled the jumper out and turned to ignition to the run position, stuck the jumper back in, and it started normally. Turned it off and put the relay back it and it continued to start normally, and has ever since. I did buy a new relay, but haven't installed it yet. I will, though. I will also replace the starter contacts, mostly as preventive, but also in case that is the source of the intermittent no start problem, which many here who know far more than me believe is my problem anyway.
Do female terminals the relay plugs into look clean and tight. Male prongs like that
