Easy Weekend Mods
I have seen PD smoke...any knowledge of how well this works?
thanks,
I dipped my headlights but only the top. Tried to smoke them with PD but that failed hardcore so I just settled with a Partially dipped headlight. Nite Shade will work but Make sure you don't over do it. Or... you can look for a light tint and let me know how that turns out. I haven't been able to tint anything in this state with the weather changing so randomly. Not yet at least...
Got any pics? I cant picture it.
I might try to do the whole remove, bake and paint process. If I do, I think I will go with a color between silver and black...
Any pics of "blacked-out" headlights that dont actually use black paint?
Did you install an amp with your headunit? I took my dash apart yesterday and decided I'm going to order the parking brake override and an amp to power the sound. If you didn't add an amp, how does it sound right out of the headunit?
Thanks in advance!
are you doing the parking break override so you can play the dvd player while you're driving...? all you have to do for that is just ground the parking break wire from the head unit into the same ground as the radio. it "tricks" the head unit into thinking that the vehicle's parking break is set all the time.
the lamin x seems easy, although a bit pricey if your doing all lights, why not do it the OG way with black candy paint and clear.. although candy is pricey, you dont need much for all the lenses, would be alot cheaper then the laminx.. although i presume the lamin x would also have a durability factor especially if offroading..
Lamin-x is very durable, plus you can remove it whenever you decide to sell. If you paint them you are pretty much going to have to replace them if you want them looking stock again.
pics or it didnt happen :snacker:
im closer, BRB calling UPS and having billed to original billing address. :frog:
Well ddnww, pictures and product got delayed. Driver kept getting calls from there dispatch, reroute to Vacaville, no go to Birmingham, no go to Vacaville.:lookout: Driver got tired of going in circles and called me, had him take it to main head quarters and call me, I'll be right there and pick it up myself. :car:
So a little late due to a couple of t4r hounds on here.
So tomorrow, 2 semi old men and my young whippersnapper will see if this is a easy weekend mod.
LMAO!!!! THAT IS AWESOME! Can't wait to see it mounted up. Congratulations!
:thumb3::pop2::hungry:
Which bumper is this?
SW bumper
Two semi old farts gave this heavy piece of steel a try, dam whipper snapper didn't show up due to " it was spring break and was just relaxing, when we going camping dad ". So here it is.
plastidip/removed running boards
this weekend i plastidipped the front grille, and removed running boards. still deciding if i like the no-running boards look, but it was pretty simple.
