How do you turn them on and off?
Just put in HVAC and speedometer LEDs from SB and Lighthouse. They look great and the HVAC cluster can easily be done in 10 minutes. Went for all white and red info display, which is more red in person.
Installed Mictuning USB ports in the center console. About an hours work.
Tapped power from the cigarette lighter (10 Amp) which I never use anyway.
One has the voltmeter which is a nice feature. Each is rated at 2.1 amps so no threat of popping the lighter fuse.
Chose blue as I'll be doing the dash lighting shortly.
Link said video not found. What was in it?
Do you have more pics about how to do this? and a product list?
How do you remove the console to get leds in there?
In my '06 Ltd, just below the controls behind the storage bin, one screw holds it in. Remove the screw an then just pull from below. The rest is a snap in thing.
Somebody should do a writeup on this. Then people could search the forum and have all the info & advice they need.![]()
Fishing pole rack
