Eibach Pro-truck lift
After going through 146 pages there has been mixed answers on clip setting bottom notch or second from the bottom. I will not have any added weight up front. I don’t want ANY factory rake and want it completely level. Not a fan of the nose down or the nose high look. Kit should be going in within the next two weeks hopefully sooner. Please let me know. Thanks
I ordered mine back in December from Wheelers...they got 12 in friday a week ago....im #14...go figure lol.
Then i was told they dont expect another shipment until the end of march.
If any or both of you get yours in the estmated shipped/delivered time....please post back here....Thanx
After two weeks with no word I checked in with ToyTec on Friday 2-26 and was told it’d be another 2-3 weeks.
Go bottom clip you’ll
Be level
Sent from my iPhone using Tapatalk Pro
Pictures.
Post #2110 i was on the bottom perch
Post #2173 i was on the second perch up.
Just sayin.
I just changed wheels/tires and am still on the second perch up.
Pictures.
Just sayin.
That’s what I want it to be like thank you. Are your running stock UCAs? If so problem with alignment?
I am running stock UCA's.
The tech at Firestone said there was no problem with the alignment(that was with the OEM 265/70/17 on a 17x7.5 wheel)
I just put the 255/75/17's on with a 17x7 wheel... and to be honest, don't know if i should have it aligned again or not.
Thanks for the info man I appreciate it!!
I'm on 2nd from bottom notch. In person looks level to me. It drives rather well. Feels almost stock to be honest. This is on 265/65r17 Falken Wildpeak AT3W and the TRD Wheels.
Whatever you do, do not do top notch unless you're running a ton of extra weight on the front. The shop I went to for whatever reason set it to the tippy top. I didn't really notice that it was setup like that. Thought maybe it would settle. But as I was greasing the SPC Control arms I had installed, I could clearly see 2 notches at the bottom. I figured the third was being covered and it was sitting at 4th perch. It was terrible. I had reverse rake. The front was SUPER stiff. The vehicle drove like poo.
Ordered end of November. Just showed up Friday! Ran out this morning and rented a spring compressor to get that out of the way. Will install when I get a few days off in a row. Going to run bottom perch for minimal lift. Pretty excited.
Thanks for the Info! Your rig looks great! I definitely wasn’t gonna top notch it but I wanted it as close to level as possible with no factory or negative rake. Even if it’s a tad bit negative would be fine to me. I just can’t stand looking at it like a drag racer..
I was curious why you opted for 265 65 at3w instead of 265 70. Is a weight yhing?
Wow, after reading through this thread I didn't know if takes months to receive the kit.
The requests for this kit have been crazy since quarantine and we can't make them fast enough.
It is not normal and we're doing everything we can to keep them in stock, including adjusting production forecasts.
Forgive me...but
Hello from Denver! First time poster, long time reader...
Bought a an Off Road Premium and ordered the Eibach kit. I’ve read some of the posts here but am still a little confused. If I set it at the first spot, there will be a slight rake and if I set it to the second it will be level?
I’m on the 1st perch but I’m looking to move it up to the 2nd perch to minimize rubbing I’m experiencing.
erinobr2000
