Fix for error code P0113 P0102
zu13
Hello all, I just got my first OBDII scanner and tried it on my new to me 4runner it is throwing 2 codes and I want to make sure that I fix them properly. As far as I can tell the truck is running fine and I dont hear or see any issues.
Once I have replaced the necessary parts will the code go away or how do I clear it out?
If your scanner doesn't have the ability to clear codes, you can just remove the negative cable from the battery for ~20 minutes to reset. Otherwise, the ECM will clear the code on it's own at some point.
Awesome thank you ill read through the manual and see if it has that feature. Any clue how to fix those error codes?
[MENTION=26691]Bossman[/MENTION] I have seen you update many threads with search results pertaining to the issue at hand which is much appreciated! I have also attempted to use the search function on this site and honestly find better results when I use google. Soooo any suggestions/tips you have to use the search function here and get the results your looking for?
Thanks for the appreciation :)
Truth be told, I also use "external" Google to search out the relevant previous threads located here on T4R.org. The key is to specify the year or generation of 4runner that the issue pertains to. I have tried to use the internal search function, but Google seems to work so much better for me.
How To Search T4R (far more accurately than standard method)
Alternate Search for T4R - 4th Gen Section
erinobr2000
