Update: After many miles of searching, Ace Hardware had this metric 20mm OD X 17mm ID X 1.5mm DIA o ring.
O ring on the left, in zip lock is oem. The right side o ring is Ace.
Along the way to Ace, I checked all the parts stores/fastener stores along the route to no avail.
So mines is a goner. I know something should be there to seal out the water and dirt that could makes it's way to the pressed in wheel bearing and contaminate it.
I was thinking of fipg'ing along the flange on the sensor. Or maybe customizing a fiber gasket to fit over the abs flange to seal out the water and dirt?
Only way to get the new o ring is to buy a new oem sensor.
This issue is a minor one, I'm just wondering what the ingenious members on here did when they came across this issue on they're own rig. Thanks
