Jacabbysal
I think I will stick with Amsoil.
Ran it in far more severe conditions in race trucks then my 4runner would ever get close to.
If $25.00 for a gallon of Mobil 1 0-20 is too expensive for you, I don't really know what to say. Walmart, best price. Absolutely no reason to ever run junk oil. You spent what, 35K - 40K on your truck? Don't treat it like a POS.
I am pretty sure he is talking about the transfer case fluid. The hard to find, $60 a quart, dealers don't even use it, fluid.
I just can't understand why so many people are dead set on not using the 75W oil? Why is that? It's proven the additives in the OEM 75W far surpass anything else available anywhere. You would think that's enough to convince even someone with zero automotive knowledge that it's a superior oil and designed like that for a reason.
So $60 is not worth knowing the PROPER fluid is in your case? Dealers not using it is the worst possible excuse out there. We all know dealers are hacks, some great mechanics but not many. For me, the $60 is more than worth the peace of mind. Put 75-90 in your case and see if Toyota covers it if it blows up. Is voiding your warranty really worth it for $60?
Ignorance resulting in fear of your unknown, explains why people like yourself hugely overpay for an OEM branded commodity product. Even Borg Warner’s engineers said that only the 75 number matters.
We’ve got 150K miles on a SR5 purchased September 2014. Over 100k of those miles are on Mobil 1 or Valvoline synthetic 75w90 with no problems and little if any filings on the magnetic plug. We intend to drive the truck to 250K or 300K. And yes we paid $35K cash and I have no fear of a transfer case failure. Rebuilt ones are around $1K.
I have no problem paying $60 for the correct fluid. For those under warranty, use the correct fluid. If you do happen to have a failure and the dealer determines you used the wrong fluid, good luck getting it covered.
Man if you're counting on a Toyota t-case failure you should definitely be buying Mega Millions tickets. I'm not sure which is longer odds. Probably the transfer case failure.
Transfer case oil isn't that magical. It doesn't get particularly hot, nor are they particularly heavily loaded gears. Because there are brass sychros in it, it just needs to not corrode the yellow metals. Theoretically, you could get away with motor oil. There are transmissions that use motor oil. I'm going to bet on mega millions.
Saying the same thing 50 times in the same thread earns you the Toyota gear oil troll award! :infidel:
I use a big open topped one with a spout on the front. When done, I use the handy attached spout to pour it into old 1 gallon motor oil containers that I always keep around just for oil storage/transport. I usually have 8-10 of those filled up on a shelf in the garage before I make the dump trip. Mine looks like this.Getting ready to do my wives limited but I am having trouble finding a reliable oil change catch basin I can use to transport to a facility.
Any suggestions would be greatly appreciated.
That's a great idea. I don't have oil gallon containers but have been saving milk jugs to do that. I just had nothing to drain it in. Thanks.I use a big open topped one with a spout on the front. When done, I use the handy attached spout to pour it into old 1 gallon motor oil containers that I always keep around just for oil storage/transport. I usually have 8-10 of those filled up on a shelf in the garage before I make the dump trip. Mine looks like this.
https://shop.advanceautoparts.com/p...gclsrc=aw.ds&dclid=CIjo4JH_lN4CFUYHDAodRRAMzQ
Just ordered similar product. Thanks again. Getting all this together costs, including oil, but I know it much cheaper than dealer.I use a big open topped one with a spout on the front. When done, I use the handy attached spout to pour it into old 1 gallon motor oil containers that I always keep around just for oil storage/transport. I usually have 8-10 of those filled up on a shelf in the garage before I make the dump trip. Mine looks like this.
