How To: AEM F/IC-6 Install, Tuning, and Help Thread
Does the F/IC-6 have the capability to skew the MAF readings?
Reason why I ask is that a Supra MAF and airbox is larger and allows a bigger intake diameter than the 4Runner onr. I did a similar swap with a VAFM swap from a Supra on my Pickup. Even on that slug of a motor I picked up some pep and MPG's.
I'm never gonna have enough money to do all the mods I want to though...
Yep it can. The guy who helped me get this all setup had a supra maf and 3" intake.
Oh man... the possibilities...
I've got the old "turbine" style MAF that costs like $600 to replace. It's so huge and takes up so much room in the intake. I'd gladly ditch it for the much smaller Supra MAF with the larger intake. Was the same concept on the VAFM swap, for whatever reason Toyota put the 4-cylinder VAFM on the V6 3.0L engine. Why? I'll never know.
Damn it man! Stop putting ideas in my head lol
I got my fic ordered and the patch harness. Aem told me I need the 30-2983 harness for my 96 auto. That should be type c from your first post, so we'll see in a few days.
O2 Sensor Type- If you don't confirm the o2 type before instal there is a chance that you won't be able to tune the 4Runner because O2 skewing will not work. For those of you with the AFR style O2 the AEM is especially appealing when compared to the URD 7th because you can tune closed loop and part throttle boost with it.
3rd Gen 4Runner:
iybcHzMzFNwwkzVL0RNScF432z6TtBi8UDnOKqW-EBY=w301-h129-no
I reread some of the post - I thought that the only models to have the AFR sensors were the "cali" style trucks, meaning all of the 2001-2002's, and then only the cali (dual cat, etc) 99-00's. I'm not sure about the manual vs auto, that's the first I've heard of that, but the link below does show different PN's for the cali auto's vs manuals. Seems like any of those -9000 series are AFR's.
Narrowband should be 96-98 and 99-00 non-cali, AFR should be 99-00 cali and all 01-02
Oxygen / AFR Sensors - Underdog Racing Development
2001 & 2002 4WD & 2WD V6; Front: 234-9002, Rear: 234-4261
2000 Cali 4WD manual V6; Front: 234-9001, Rear: 234-4153 2000 Cali 2WD manual V6; Front: 234-9001, Rear: 234-4155
1999 & 2000 Cali auto, 2WD/4WD V6; Front: 234-9002
1999 & 2000 Cali auto, 2WD V6; Rear: 234-4155 1999 & 2000 Cali auto, 4WD V6; Rear: 234-4153
1999 California manual V6 2WD/4WD 4Runner; Front = 234-9003
1999 California manual V6 4Runner; 2WD Rear = 234-4155 1999 California manual V6 4Runner; 4WD Rear = 234-4153
1999 & 2000 49 State 2WD & 4WD auto V6; Front = 234-4162 1999 & 2000 49 State 2WD & 4WD auto V6; Rear = 234-4162
1999 & 2000 49 State manual V6 2WD; Front: 234-4162 1999 & 2000 49 State manual V6 4WD; Front: 234-4161 1999 & 2000 49 State manual V6 2WD & 4WD; Rear: 234-4154
BTW - Computer shows up today...
I put a ton of research into the o2 sensor setups toyota used, that chart is 100% correct ;)
Can you explain / elaborate a bit then on the difference on the 99-00's? Every place I have read has said AFR for the cali's, and narrowband on the fed's.
For example:
Ignore the red markups - cali says AF sensor, non says O2 sensor.
For example:
It was a transition year so the Cali runners got afr and others were narrowband. Look at the chart it says 99 Cali auto is afr and 99 (assumed to be the rest is narrow band.
Ahhh ic what ya mean I put 98 instead of to 99. But regardless it specifically says call 99 for the afr version. And manuals were always shipped with the narrowband sensors.
Awesome. I'm hoping I can find some time this weekend and that the garage heater keeps up... Low was 4 degrees today! Can't wait to rip out the split second
Installed my AEM Boost/AFR guage, Boomslang harness and FIC/6 - SC has 2.1 pulley - Plugged it in and set RPM, looked around at available settings trying to get use to what I am doing. Drove around and was watching everything - didn't adjust anything. Watching AFR, at 9.7# of boost it is at 12.5 AFR on the wideband AEM guage. For fun I dumped in 2 gallons of Unleaded race gas and it will no longer ping - audible -at any RPM or throttle position and still stays at 12-13 AFR and maked GOBS more power. Just playing a bit with it seeing how to work with it.
Haven't installed the Meth injection that is sitting here yet.
However with the the AEM FIC/6 and Boomslang harness when it is cold - 29' here now - it will not start, cranks and cranks but will not start, unhook Boomslang harness and go back to normal and it fires right up, switch back and nothing. Once it warms up it starts fine with the FIC/6 hooked up......
I was thinking it just was able to adjust from where it is set and with no adjustments it should remain untouched...?
Still learning...
2000 Fed 5 speed = Narrowband
So much to learn for an old school carb/distributor guy LOL
Still learning...
Sounds like boomslang has the resistor for the cam circuit in the wrong place. That's exactly what mine did while I was getting everything set for this write up. Any codes?
No codes, but only when cold, was fine when 40-50'....
I metered it and was pretty sure it was in the correct position, I checked.
I will say I haven't installed or even checked to see if there is a 1K or 10K ohm resistor for the O2...... And trying to figure out the O2 on the FIC. since I have a Wideband hooked to it and the factory one is wired in... I havent messed with it enough to figure it out on the Gauge screen
Not having much time to mess with
It will start and run fine with the o2 unhooked, so that can't be it. You said its cold there today?
charlesz
