InfamousRNR's 2002 Limited BU!LD THREAD
Here's my 98 EWD
I have no clue where the fuse is. Look at the EWD above. There are 3 fuses. I'll try to locate them for you
Finally put on the lateral control rod (aka panhard bar) with 7/8" heims from RuffStuff specialties on that was line-x'd.
Thank you [MENTION=120071]mtbtim[/MENTION] for your tool time and expertise !!
How much did that cost you in parts and welding? Im not sure whether i want to get my panhard bar drop bracket welded, order a SS adjustable bar, or make one like you did.
Jay
I think I am a little late, but figured I'd post anyway.
With regard to the trans flush:
I was under the impression that the only time this was considered an issue was when you hooked it up to a machine which *could* apply more pressure to the system than the factory pump, thus dislodging crap.
When using the factory pump to push out the fluid I do not see how there could possibly be an issue. It's the same as running your truck, just introducing new fluids at the rate of which you're removing the old. This is also how I do it, and have never thought twice about it.
With regard to the line-x on your panhard bar:
You should have sticker bombed it.
Jay
The heims from RuffStuff specialties were like $80..
The bar was given to me and I gave [MENTION=83666]renosauce[/MENTION] $$$ for his amazing welding skills on the bar and my shelling me slap my sliders on.
Highly recommend his skills
But I guess I would say ~ $150....
But I 100% will go poly bushings next time around... Or even OEM bushings...
I ran out of stickers!!!! :-((
The DOM bar itself was dinged up pretty good so it wasn't a smooth surface... I thought the line-X would hide the scares this bar had...
Finally made an acrylic piece to hold my Scangauge II
It is basically a clear price of 1/8" plastic from tap plastics, 2 holes drilled through to secure to the radio surround in place of the ash tray & the scangauge II is secured to the plastic with 3M double sided tape.
More dynamat. I procrastinate to the n'th degree. I pulled the carpet 3 weeks ago!!! Driving around without a passenger seat. Because of this impending installation
... So far with the entire rear and one door and most of the floor... I foresee 1 more purchase which would make 3 orders total....at $150 an order (9 sheets 36 square feet) I'm about to be at $450 just for dynamat. Ouch. Is it worth it?.... Hard to say. I've been really trying to install it perfectly.... Especially because everyone will see it under the carpet..................
... So far with the entire rear and one door and most of the floor... I foresee 1 more purchase which would make 3 orders total....at $150 an order (8 sheets) I'm about to be at $450 just for dynamat. Ouch. Is it worth it?.... Hard to say. I've been really trying to install it perfectly.... Especially because everyone will see it under the carpet..................
Wonder how much they all weighs?
how did the plastydip smoke work for you? i like what you have done and am thinking about blacking out some of my lights now
4runner Mafia @ Hollister Hills
Huge shoutout to [MENTION=109477]Rorck[/MENTION] [MENTION=131927]4runnermafia[/MENTION] & Adams Polishes for the Hollister Hills 4runner Mafia event help yesterday Aug 20th.
You can catch Rorck Clothing on RORCK.com
4runner mafia on Instagram
& Adams Polishes on Adamspolishes.com
Beautiful day with some fun trails and good company.
One killer build for sure. Digging all the plastidip, as I did my rims and badges a little while ago. Not a huge fan of all the stickers but hey if you like it might as well :jump:
The only stickers I have now are on my window...
It's line-x bed liner. Permanent . Plasti dip is temporary
freddygino
