ISO cluster repair
1bzdvl
Member
I'm looking for a good shop that can look at and hopefully repair my gauge cluster. I'm in Phoenix, but I'm open to shipping for a good recommendation. Thank you.
2000 SR5 5spd 3.4
CEL p0500. ECM is not getting signal from the cluster.
2000 SR5 5spd 3.4
Bump - interested in this as well - have a 2004 Tacoma with a dead speedometer.
I ended up taking it to a local shop. Dick's Speedo-tac. They called me and let me know they didn't find anything wrong with it. I'm beginning to think I have a bad harness based on some testing I just did on resistance between the pins on the plug of interest.
I checked out that Tanin company earlier as I had seen some listings on eBay. Unfortunately, the only MT purposed cluster is for a 4cyl, and I've seen mentions that it won't work. But thank you for the suggestion.
I'm back to square one. The shop didn't diagnose the cluster for the p0500 code. They just tested the speedometer, and since it worked, they called it a day. I explained that I wasn't getting signal at the ECU from the speedometer, and they quickly responded that it must have a bad processor. Considering they didn't look at that, it felt like they were guessing, and I kindly requested the meter back.
