jam23r1's Runner build
just wondering if any one is in the Newport news va area. trying to do a weekly or by weekly meet for Toyota 4x4's
so I have not done an update lately. wife got me this for xmas! 8, 4'' led lights for my roof rack and grill. new red top.
just need some time to install everything.
Is the red top going to be your aux battery? What tray are you using and which controller?
yes the red top will be my 2nd battery. ill more the likely fab a tray for it. I don't know yet on the controller. I 'm gathering all the parts as I go. so that I'm not dropping a bunch on money at one time. I should have it all done by the end of the month.
what would be a real good controller? this stuff is not my strong point. I have a good friend who will be helping me wire it all in. so any info would be nice.
The most simple one to wire up would be the one from IBS. I think [MENTION=62008]limamike[/MENTION] is running it and I'm sure could walk you through the install process.
If wiring is not your strong point, this tried and true method by [MENTION=47340]Titanpat57[/MENTION] is pretty simple to follow along and execute: http://www.toyota-4runner.org/5th-gen-t4rs/125772-dual-batteries-cheap.html
Of course wiring up a controller like the IBS is not toooo much harder either, just a few extra wires really, so pick your poison and if you get stuck along the way I'm sure someone here can help you out :)
^^ What he said. The IBS instructions are fairly easy to follow. The most difficult part of the install is finding a place to mount the relays and running the wires!
EDIT: It's not a cheap solution, though. Depending on what you're wanting to run the aux battery for you might be better off with the solution that he linked to over at Expo.
thanks guys!!! the 2nd one will be for AIR Winch and lights.
The Optima red tops are their starting(normal) batteries and not made for an aux battery that will be deep cycled. The plates are closer together on starting batteries and will not last if run down below 10v many times and will burn out a cell,which leads to failure.
Their Yellow top and Blue top are dual purpose deep cycle and starting and MUCH better choice for an aux battery and will last 10 times longer as an aux battery. I would see if they would do an exchange as the price isn't that different.
REDTOP® High-Performance AGM Batteries | OPTIMABATTERIES
BLUETOP® High-Performance AGM Boat & RV Batteries | OPTIMABATTERIES
YELLOWTOP® Deep-Cycle AGM Batteries | OPTIMABATTERIES
Blue tops and yellow tops are the same with the blues just having extra threaded post on top for easier accessory hook up and why they make a good aux battery.
HowStuffWorks "What's the difference between a normal car battery and a deep-cycle battery?"
http://www.dekabatteries.com/assets/base/0149.pdf
wow I did not know that thank you so much for that. I would have been vary mad killing a new red top.:clap2:
Hey, not sure if this is true, but I remember reading that you shouldn't wire the winch to the aux battery and that it is better to hook it to the main instead? I never really looked into it past that because I don't have a winch, lol. Maybe if I were you I would research a little bit more just to see which way is the preferred method before you start wiring the winch :)
This depends heavily on what you have wired to what. The theory is that if you wire to your main and run-down the battery you'll still have your auxiliary to help jump the main. However, that's assuming you've got all of your accessories wired to your main. My feeling is that if you have your accessories wired to your auxiliary battery then stick with that as the source of power for ALL accessories.
The reason for using the main battery for winch applications is the amp draw. Ideally, the vehicle is running and will be able to handle the amp draw while using the winch.
If the truck is running then both batteries should be connected to the alternator.
