LC2013`s build thread
i changed to the 06 headlights with the blinker in it. Much better this way, easy swap.
Did the socket fit from the fog turn signal? Luckily i did the 06+ as well but my turn is empty in the headlight.
Sent from my SM-G930P using Tapatalk
its a whole new harness from toyota i soldered on after snipping existing plugs. Then added correct plugs to my pods and plugged them into the fog harness. Plug n Play.
New lower control arm stuff.....
So Im trying to confirm that I have the proper parts for the lower control arm bushings and cam/caster bolts.....does this seem about right?
I was hoping it would be cheaper.......man OEM is expensive.
Bumper off......painted it all nice behind.
Bumper on
New light bar to fill up the bumper gap.
I also got a new winch....unfortunately they didn't send me the one with a synthetic line so I had to send it back -_-.
LC2013... 2 things. How's that backup camera holding up? I see versions of it on Amazon all the time. And on your USB/AUX you installed, is the aux connected to your pioneer?
Sent from my Nexus 5X using Tapatalk
It's actually holding up great. I also installed one on my girlfriends car, and now my buddy wants one.
Yep it sure is.
Great. I'm gonna grab a very similar camera then. And I'd love to know how you hooked that AUX up. That's the set up I want too.
Installed extended sway bar end links and prepped/painted the rear to get rid of the unsightly rust.
It isnt smooth because I used undercoating ......hopefully it helps with chipping.
Went floating and took some pics.
Sent from my SM-G930V using Tapatalk
Beautiful rig!
looking good
Thanks guys!!
So question for whoever reads this........I have a chance to pick up a local pair of Icon ext travel coil overs w/ approximately 20k on them for $700 (includes spanner).
Should I jump on it or? Pics below.....
Fish4runna
