Leaking CV boots after lift??
I tore my original inner boots after I lifted, didn't surprise me due to age. Bought some Toyota boot kits from camelback and installed. They tore again. So the second round I stretched the inner boots as many have done, cutting the old boot off and leaving part of the old boot and clamp in place, stretched the new boot over and reclamped. Been about a year and all is well.
My boots tore from the two flutes on the boot closet to the diff rubbing on each other and eventually tearing. The friction will actually wear a channel or groove into the rubber while in rotation to the point that the boot material is so thin that it just gives out and spews that grease everywhere.
I had same exact proble that just happened to me. I went and did the hose clamps and stretched the inner boot out on the axle a bit. Now it's leaking a little from the inside (closest to diff) and hose clamps I've found were too wide, which sux cuz I already cut the clamp. Figured after 220k miles on it they would be ripped or torn, I don't wheel easy, but they look to be in great shape. Has anyone tried hose clamps on the inner part of the boot? All write ups talk about outer part of inner boot.
Also how is everyone's undercarriage and all that stuff so clean? I spent a good 30 mins scrubbing those axles to get all the grease and mud off before I shifted my boots
Reviving this thread as well. Tore mine when lifting. Are reboot kits the best way to go? My guy won’t do the alignment until I replace them.
Afraid I'm looking at the same thing. Front right CV is sprayed with liquid. Not on any of the other wheels. Just had a 3" lift done a month ago.
2hMKeLm
2hMKeLm
This video might help you out:
<iframe width="560" height="315" src="https://www.youtube.com/embed/vcCT4UgFUTw" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
2hMKeLm
It is very common for the CV boots to "Burp" a little grease out when lifts are changed, modded, or new CV's (with new boots) are put on. The grease needs to go somewhere as the shaft angle changes inside the CV, and sometimes the easiest route is to just burp a little bit out. As long as the boot is not torn, I wouldn't be too concerned.
From the look of the pic, I'd wager his boot is torn. After a lift, they usually fail one of two ways. The new angle causes strain on an old and less pliable boot and the inside boot tears at the narrow end at the juncture of the thick shoulder that the clamp goes onto and the main part of the boot. The second way they fail is the new angle causes the boots ribs to rub together. When they rub together it creates friction and the boot tears. Analyzing the pic, it looks like his boot tore due to friction between the boot ribs.
I just lifted 2.5 Inches in the front and I've experienced grease come out but in all honesty if you think about it when you increase your angle on the boot obviously it flexes more leaving less actual space for grease to occupy so its logical why that grease would come out. I lost a couple oz like what you describe about 3k miles ago and I've experienced no issues nor noise from my CVs. Knock on wood.
That makes me believe mine will be ok. I think mine leaked due to the "new" angle the CV joint is running at now, due to the lift. This is my thought: The boot was full of grease while the CV joint was running level, and now that it is running at an angle...there is too much grease in the boot. Therefore, the "extra" grease now has been forced out...so, now it should be ok! I wiped off all the grease and since then...we are leak free. At least that's what I hope has happened.
Lolol guess I should read the entire thread first. My thoughts were the same. Good luck!
Well, instead of a bunch of conjecture here, the member from Post #26 needs to simply examine his boot to see if it's torn. His doesn't look like a burp. His looks like it threw up.
Yes- as I said, as long as the boot is NOT torn, I wouldn't be too concerned.
After researching around a bit, I agree they are likely torn from the change in angle. No noises or general disturbances noted yet. Have read about some people letting them go all through winter like this. I probably won't do that but good to know I've got a little time cushion before I will have to have it fixed.
Gave it a good cleaning, and a few days later it was sprayed again. I'll get in there for a close look today and post a picture if I can.
Finally looked closer.
Read: projectile vomit.
Ok just got in there for a closer look finally. The wide end seal seems intact from what I can see (I could be missing something small up close to the clamp though). Wondering if it could be an extreme case of the burps...maybe just need re-clamped/tightened up.
Picture for reference. The narrow end looks ok (and dry).
I rebooted at the time that I installed my SS 1.2 and experienced a little "burping" from the larger end on the passenger side. I was initially worried about a tear in the new boot, but all appears to be well after loosing a bit of grease. I ordered some worm gear style clamps from McMaster and plan to swap out the crimp type clamps per some other suggestions.
Did you check all the way around the boot? Might be easiest to jack the affected side tire off the ground and spin the wheel while looking.
