Lift and Tire Central (pics)... Post 'em Up!
Yep, I looked into them also, but I couldn't justify the price, I finally went with Toyo Open Country AT2 which are rated for 65k miles. Out the door price was 950.00ish in 285/60/18.
AT2 is likely what I will end up going with. It's about 500.00 less than the same setup I've priced in the KO2, and I see nothing but good reviews on them.
He's in Texas, everything's bigger.
Looks closer to ~5-6" imo, he can get a bit more lift since he has the 2WD model, but idk
Still, he's not running 35's, not enough trimming to accommodate them, and there's not enough gap for 33's and that much lift. I call shenanigans.
Toyo ATII Fox Racing 2.5 w/res
Toyo ATII 275/65-18 supporting front Fox Racing 2.5 adjustable with remotes, Icon tubular ucas. Rear Fox 2.5 with adj remotes OME 889-E 1.5" driver side 20mm spacer.
I've thought about doing it as well, but can't stomach it without re-gearing the rear end. Keep us posted, Morris!
I still have plenty of tread on my current tires but with the cost of 35's you can't start saving too early....lol. Plus i would have to install a BL before hand as well.......and possibly gears.
What lift are you running??
Front
Bilsteins 5100 set to .75'' of lift
Maxtrac 4'' lift spindles
Stock springs (because once I put the Toytech front springs on and had the 5100's set to 2.5'' of lift and then took it off the lift I had gained 12'' from where I started.) :frusty:
Rear
Bilsteins 5100
2'' All-pro springs
I ended up with a ground to bottom of fender measurement of 40'' all the way around within a quarter of an inch.
Love the way it rides and sits now. Its a brand new truck!
[MENTION=133348]tc05runner[/MENTION] It looks awesome, but I think it would be even better with a little more height! maybe another 1.5/2"
What lift do you have now?
I just installed some KO2s in a 285/70-17. I took off 305/65-17 KM2s and was trying to fit 285/75-17 KM2s but they we're less then a 1/4" from my sliders so there is no way they would work. I already have the body mount chopped but the sliders are welded in 4 places down the Fram so they're there to stay. I'm not entirely sure I like the way it looks with 285s but they don't rub. The 1st pic is with the old tires, the two pics with the tires standing next to the truck are the 285/75-17. They looked fantastic on the rig, just weren't gonna work.
Ambrose67
