Limited Edition Mod Thread
Well after waiting 4 months for all the parts to arrive I’m happy to say the my Yukon 488 gearing and Rear Eaton ELocker is installed and running great! Best mod I have done in a awhile. Time to break them in and hit the trails[emoji1689]
https://uploads.tapatalk-cdn.com/20210729/d5e7933302015f522597a2ac3c1b0cf0.jpg
https://uploads.tapatalk-cdn.com/20210729/318ebcffd3365db6ba94e502d62d77c3.jpg
https://uploads.tapatalk-cdn.com/20210729/3bd127bf6271fcbc126cbb78fd2df9a8.jpg
https://uploads.tapatalk-cdn.com/20210729/2c08cf6243a19cb7ec7cc4088e436012.jpg
https://uploads.tapatalk-cdn.com/20210729/a8ea0e426be3120a7c397ac0fec48814.jpg
I would like to do the same sometime in the future. Did you re-gear the front or just the rear?
Just trim the rocker, it looks so much better in my opinion. Recently trimmed mine in preparation for rock sliders to arrive.
[MENTION=468417]DaveSki[/MENTION] - Do you have additional photos of how your trimmed your stock rocker covers? Any close ups?
Finally got rear bumper sprayed and installed.... slowly moving along.
My dealer struggled with matching the paint... a shade too light (not enough yellow), but all the other work is so well done I kinda hate to respray...which they make make worse the 2nd time around...
almost done collecting front end parts...
[MENTION=392483]silverado1957[/MENTION] - What rockers did you use here? They look like they match the rear finder trim. Did you trim the factory or did you use Early edition trail parts here?
[MENTION=392483]silverado1957[/MENTION] - What rockers did you use here? They look like they match the rear finder trim. Did you trim the factory or did you use Early edition trail parts here?[/QUOTE]
I used 2018 SR5 OEM rocker panels opposed to cutting and then replaced the rear flares on doors with SR5 OEM flares that were paint matched...
I attempted a search but couldn't come up with any results. And, this will apply to more than just the Limited, but since I have a Limited, I'm asking here.
Is there a mod yet to run the fogs independently of the headlights to be used by themselves and/or while the high beams are on (aside from rewiring them with their own switch)?
Is that a no?
For those of you who have upgraded the suspension (XREAS delete), did you happen to notice if the front coils are different on the left and right side? I haven't taken the wheels off my '15 4RL but when I look at the left front coil, I see eight turns of the coil and only six turns of the coil on the right side. When I research the part numbers of the coils, none of the sites show an actual picture of the part (just a drawing of the part) so I can't tell if I'm seeing eight on the driver's side because my shock is shot (it's leaking and probably near empty) and therefore compressed or if it's legitimately a more aggressive coil than the right side.
The left coil costs about $40 more than the right, which makes me think the left one is beefier than the right side. The aftermarket struts I'm looking at appear to have the same spring for both left and right.
Just curious...
Just curious...
Yes, you're correct and it's due to the increased load on the driver's side. For aftermarket they compensate with either a spacer on the driver's side or different height settings like with Bilstein 6112's they do a 7/5 circlip setting.
Does anyone make a plastic slimline bumper for the early 5th Gen's (I have a 2012 Limited)? I would love something like the C4 Fab or 4x4 labs full length, just in plastic. My off roading these days consists of the very occasional forest service roads and beach driving. I would like a little more approach angle for the beach when the sand gets a little soft, the extra room for a little larger tire would be nice too. I would just get a metal bumper but I would just have no use for it, it's not like I'm going trail bashing or rock crawling. I would rather save the money for other add-ons.
Cut the bumper
Baja kits 2” LT
custom fox 2.5 race LT coilovers built and tuned for 4R
icon billet rear lower link(worthless but got it for like $50)
2.5 fox tundra rear shocks for more travel tuned for the 4Runner
Fox IFP bump stops for raptors that were tuned for 4R w/total chaos mounts
Fuel 17” rims w/ 33” trail grap
Engine mounts gussets
Rear spacers my friends and I put on the LT which became a huge ordeal and everything else was put on at down east Offroad in NC. I built it for desert running.
Cut the bumper
Baja kits 2” LT
How much travel do you get from the Baja Kits 2" kit? Hit the fenders badly?
Props to you for setting up a Limited more for speed. Looks great.
I get full travel with stock fenders at the moment. It has about a quarter inch of space when in full compression between the tire and the fender. Regardless I’m getting the fiberglass fenders painted as we speak. It is kind of an anomaly in regards to it being a limited and a 4Runner with the set up but I’ve had a lot of fun adding and subtracting from it. It also gives me something to spend money on and learn everything. It started with mid travel icon stuff when I didn’t really have a direction for it and just wanted it to not look like a limited. I plan on adding a secondary shock up front and maybe doing something kind of crazy with the rear shock mounting position later this year but we’ll see. It’s more of a time constraint issue with doing everything I want to it at this point.
Cut the bumper
Baja kits 2” LT
sweet baby jesus that looks nice
Cut the bumper
Baja kits 2” LT
you win this thread
Was wondering if you were going to go fiberglass up front, and if so was going to ask if you saw Dirt King's LT kit for the 4Runner? You'd gain 2.5+" of travel and it'd be 3" wider overall. You'd need extended axle shafts and diff drop kit would be a good idea.
I'd also suggest getting spindle gussets. The spindles are forged steel, so they won't just snap, but they'll bend on bigger hits. Do you have some progressive bumpstops up front?
For the rear, there are some good 3 link kits out there that pull impressive travel. Need extended brake lines and I'd recommend running limit straps (all around really with the $$ shocks).
I got the Baja kit 2” at a steal from some guy that happened to be in my area and took them off his truck to sell it. He sat on them for awhile and sold the complete axles as well for around 1.5. I plan on going wider I just need to find the right one and I’ve been putting the back together for some time now so it’s been on the back burner. I’m always all for more travel but like I said, it was hard to pass that deal up considering the extensions without the complete setup cost around 700. Dirt kings customer service is amazing though i was in a jam with the tie rod extensions and they had them to me the next day. haven’t really gotten into the links yet because I really don’t know what exactly would change or how it changes anything and how much more travel that would get me. Any input is completely welcome on that. I don’t know anything about bump stops up front either! I need to gusset everything and I want to get motor mount gussets but im having a hard time finding them. The hardest part of this whole build has been finding info for this kind of build. I am in constant email threads with manufacturers but even they have a hard time with it sometimes. Accutune has also been a huge help in that regard. I have the straps for the front I just haven’t had time to take them to get welded and would like to have all that together for when I take it.
erinobr2000
