Lug nut torque...what value do YOU use?
I have had very good luck with Discount Tire who I have dealt with like forever.
Yesterday when I had my TRD wheels mounted, I stressed DO NOT over-torque them and watched them torque them. They did it to the letter.
I believe lesser shops over-torque due to either:
1) Laziness
2) Lack of knowledge (see #1)
3) Baseless fear of lawsuits for a wheel "falling off"
It's only #1. Wheels that are overtorqued fall off too. That's when 99% of failures happen. It's critical to have them all the same. It's much safer to have them all at 75lbs than 2 at 80, 2 at 90 and 2 at 130.
Sent from my SM-N900P using Tapatalk
most tire shops love using the air guns to put the lugs on then they check the torque IF its low but what if they gunned the lugs on too tight ?
today I was working a 2006 charger hemi 5.7L. checked out the wheels/lugs and the pressure sensors, tire rotation . could not get the lugs loose with out the use of a 3ft breaker bar and some rust penetrating oil .
too many times this is happening ....
whether or not it is useful for the shop remains to be seen, but I have a piece of tape on the locking lug socket in the glove box that reads "85 ft.lb". They sure can't say they didn't see it.
I re-torque my lugs after 100km anyway.
The reason for the different torque values is In the owners manual , the alloy wheels vs steel wheels have a different torque.
If they overtorque - it may cause plastic deformation (meaning it won't return to its original form). Like this
That's bad. Next this happens:
Then this
Good for you. You paid more and got screwed over. :moon:
To be fair, it is over-priced; but it's very well built and useful. The reason I bought my 1/2" Torque wrench is because it ranges between 12ft.lbs to 250ft.lbs, does multiple variances in units, and also does degrees while memorizing progress (so if you're in a tight space and you can only manage 60 degrees out of 90, it knows when you've hit 90 total).
It's overpriced, but it's a good tool and it's under warranty; I could have wasted weeks hunting for the best value vs. quality and come up with one a couple hundred cheaper, but then again; most people on this forum just need a torque wrench for their lug nuts. They don't really use it for anything else.
I could have gotten into it about quality and how I DIDN'T get screwed but not worth it. Snap-On makes the finest tools on the market IMO, I can afford them, and they've never let me down. Not once.
My Dad used to say "Buy a cheap tool, you buy it ten times. Buy a good tool, you buy it once".
But again, like the oil debate, not interested in arguing about it. :-)
The reality is the quality of your wrench (unless its grossly out of range) wont matter as the k values will vary greatly and IIRC industry standard (petrochem) for using a torque wrench to determine fastener preload was in the range of +/-20%. Get strain gauges on your studs then I will be impressed :)
hahaha! I can see it now... instead of instead of installing phone mounts they will be asking what the best data logger mount is. We could go with laser gauges...
Is it wet when you install the lug nuts? Did you use air to blow off every last drop? If you didn't your torque value will be in that 20% range.
Classic. I spent the time writing up that TLDR post and nobody reads it. The chances of you getting your torque EXACTLY right is slim to none and slim just left town. Get it close with any decent torque wrench and that's good enough.
Hey! Mine beeps and flashes green lights when I get it within that 20% value! :flipoff:
lol j/k
Best torque wrench in the world is pretty much useless if you don't keep it calibrated.
Just stirring the pot. lol:couch2:
The snap on tool line is what most techs use when your in this auto repair business. a reliable tool is important. good service.
for DIY the use of lower cost/quality tools with a warranty is sufficient.
torque on a wheel is not all that critical like torque on the heads. stud stretch is important so that is in the proper amount , so that it will not weaken the metal , wheel studs don't see the heat stress like heads do.
doing this wheel torque check yourself will save you , should you get a flat and then you find the lugs won't come off.
another tire shop issue I have seen is they use worn out sockets which round off the corners of the lugs. then your wrench will not fit.
I have stopped to help owners with this issue several times.
