Magnuson Supercharger for 2010-Present & 2010-2014 FJ
It all depends on the tune and a comparison to a V8 with a supercharger and a v6 isnt a fair comparison. You also dont want too much immediate tq or you will start breaking things especially if your stock. The curve on the tune currently being ran is very smooth and has power when you need it.
I guess there are a few different philosophies.
I would prefer low-end torque in a truck. The throttle response driving in town won't be an issue if you have proper throttle deadening. (Don't install a sprint booster).
A supercharger is probably easier to mount than a turbo in our application, but if you don't have the lower-end power a typical supercharger gives you you're missing the biggest performance benefit that it has over a turbo.
It is not recommended to install an SB. This kit is relatively easy for the mechanically inclined. The instructions are extremely thorough and those who have never installed one will be able to do it if they take their time. You are getting a significant increase and response in tq compared to stock. However, it isnt tuned to just be snappy to the point where you could break something. You have an increase however it is gradual. I dont know of any tuner where power/tq gained isnt adjusted gradually. You want a smooth curve throughout the powerband and the timing needs to make sense.
If your graph looks like Hellen Keller took a go at it, you're gonna have a bad day.
The 8" rear diff hardly holds up to what I've been doing in the rocks with the stock V8. Of course I've got a lot of extra weight and 35's but I killed the original diff by not doing a whole lot. We'll see how the new diff with the solid pinion spacer holds up...
It's hard to tell what the stock vs supercharged dyno graph may be by guessing at this point (I haven't seen one anyway...) But with a supercharger I've always thought you do get a decent boost at the lower RPMs too. Check out this F150 dyno run. +30hp and +100tq at 2000rpm. If the 4Runner graph resembles this trend, it might be closer to +15hp and +40tq so maybe not much, but like I said, IMO the OEM diff can't really handle stock power on the rocks with 34s-35s and extra weight, let alone adding a supercharger on top of things.
Stating the obvious but if you have a 4th gen different rear diff. 8" vs 8.2. Not really a size difference in reality, but it is stronger. Seen the 4th gen one break quite often. Still have not seen a 5th one break yet. Not saying it won't... just seems to be quite a bit better. The housing and shafts probably have worse limits than the diff. You break stuff with a heavy foot and big tires.... Shock loads will bust up just about anything other than a Dana 60 or other custom axle with all chromoly...
Front end is a different story and should be the same.. Still CVs typically let go before the diff.
There will be some boost down low, just not without throttle... we can speculate all day... but driving it will truly be the only way to tell for sure what it feels like.
The supercharger will not cause you to break in the rocks.. Your right foot might.
My concern with the axle is going up a pass with a trailer, I step on the throttle and get a hard down shift. For me that's pretty normal use. In generally I think the 8.2 has proven to be pretty reliable and durable. I'm not sure if anyone has broken one yet. If they have I haven't seen much info about it. Front Range builds a direct bolt in Toyota 9.5 housing that retains all the parts except the differential and housing - so it's fixable without a huge price tag. Or a limited with AWD is Toyota's default solution. But I am curious how hard Magnuson has pushed it's test mule.
We are mostly if not 100% agreeing with each other.
I will add; 100hp 4 cylinder trucks can break shafts and differentials just as easily due to their stupid high crawl ratios in their differentials. It has to do with torque.
So either way you are going to break stuff in the rocks. :) Driving slower is a bit more controlled but sometimes you need momentum.
I think if Toyota uses the same crush washer in the 8.2 its only a matter of time until they weaken... Although it does seem they are a bit more durable, if the FJ crowd is any indication.
It was tested pretty thoroughly on its way to FJ, to AZ, and many times on the dyno. They know what they are doing when it comes to testing. If they didnt, they wouldn't be as successful as they are. I can tell you I personally have had some fun with it.
I've seen 5th gen blow a rear-end, the same way the 2nd gen Tundra, 1st gen Tundra, and 2 Tacomas did this year. They spooled up on ice and when they finally hit pavement it shattered the rear-end (One Tacoma shoved a 1/4 of the ring gear into the housing hard enough that the tip of it was poking out). That's not including 1 Tundra front diff and 2 transfer cases.
Bottom line, not driving the vehicle properly will grenade your diff more than adding a supercharger will. Also keep in mind that the 4th gens used the same rear-end for both the V6 & V8 (gearing was different) and they didn't explode regularly with how often people use their V8's for towing and abuse.
Geesuz, understandable you could damage to failure in that that scenario but sending a shard through the casing, that is pretty crazy.
I wish I snagged a picture, was the most impressive rear-end failure I've seen in a while. It wasn't a shard, it broke a 1/4 of the ring gear off and shoved it into the housing so hard it started poking out the other end.
I havent read the whole thread ...
what programmer are you guys using for tuning ???
Magnuson has proprietary tuning capability for the Toyota ECUs where they can modify the stock calibration.
They will ship the kit with a canned tune for your ECU.
There are a few tuning shops that claim to have recently achieved a similar ability. One that I know of for sure is DAP in Dallas, TX. But they can only do it on the dyno at the moment. I will probably take my truck to him at some point for a custom tune since I may do a few other things to it....
Another option is the URD piggyback. That should be available very soon.
matisgugle
