Evening yall,
I wanted to give all of you an update as to my personal experience with the supercharger. Im sure by now you all know that I do not work for Magnuson. I just happened to be in the right place and the right time to have been fortunately placed to assist in the process. I have had my kit on for some time and wanted to give yall some real life experience with it. I can tell you up front that I have yet to get bored with it and it still impresses me. I have given many people rides in it and many have driven it and the experience is all the same.
Many of you ask about MPG and it really comes down to how hard you're driving it. When I first got the kit, some time ago, I babied it for the first few hundred miles. Coming from the car scene and massive turbo setups, I am used to doing so to insure proper break in. With these kits you don't necessarily have to do that but its just my way of doing things. Prior to purchase these kits are tested very thoroughly. My MPG during that time honestly got better. Not by much but its something. I was right around 14+. I wasn't constantly dropping gears to maintain speed, it didn't struggle to get up a hill and maintained what appears to be lower rpms at cruise. I will say that I saw better MPG whilst not utilizing cruise control. After that "break-in period" it has dropped. I'm currently sitting at 12MPG but keep in mind that's because of aggressive accelerations and testing out each gear to see if there is any drops in performance or timing etc. It is also from giving people rides and letting others drive the vehicle. Testing hard accelerations on flat, up hill etc. It works fine in 4H and 4L and under crawl control conditions. There is currently another tune that will be uploaded and it is showing great numbers. It was tested under some heavy load testing and other conditions and it performed flawlessly.
I am currently working on relocating the heat exchanger pump and coolant lines that run to it due to winch location. Its a tight fit and for some will be a must depending on the size of their winch. Not a big deal and is something that can easily be done. Ill post pictures soon. If you have any questions, please feel free to reach out.
