RonMAIDEN
Super Moderator
moto377 said:I have 2000 4Runner Limited 4.3L, and get around 270 miles tank. When filling up the fuel pumps clicks off real early on the 4Runners. I can usually squeek in another 3 gallons, but I have to nurse it in REAL SLOW otherwise the pump keeps shutting off.
Anyone know of a mod to the 4Runners fuel downspount so that it doesn't fill up so quickly (evenb though the tank can still hold another 3 or so gallons)? When you fill up all the way, you get that extra 50 miles or so to the tank.
And you are slowly killing the evaportative canister by overfilling the tank. You should stop when it clicks than go one more time til it clicks then call it full. The tank is officially 18 gallons but a gallon or so is unuseable since the pump doersn't sit on the bottom of the tank. Even when I think mine's about dry the most I can fill up with is about 15.5-16 gallons.
Gas vapors need that extra room to expand when heat builds up and if it can't expand it forces raw gas to saturate your charcoal canister causing it to fail and it'll cost you a couple hundred to replace.
