My 98 Limited
I decided not to paint the FZJ80 rims and leave it alone because it's going to be used only when wheeled. I got the Toyo M/Ts mounted & balanced. Tires are 265/75R16.
Never posted here but cool rig, I like front end. Those treads on those tires make them look big to me. Any chance you have pics of the calipers where they were shaved for clearance?
Thanks! I sanded in the pictures below, where the trd sticker Is placed. More in the middle.
The calipers is not mines. It's speedys garages picture. I'm not in the mood to take my rim off at the moment.
I just finished installing my new remand alt that lasted 1.5 months.
Also started on another project. It's and VIAIR 380C compressor. I just got it mounted and will be wiring it up when my 3gal tank comes in. Got it used for cheap.
Put my mountain wheels on because we're supposed to go wheeling tomorrow.
On Monday I installed another Blue Seas dual USB charger in the 2nd row ash tray. Nobody smokes, so I put it there. Now I have 1 USB charger in the front and 1 in the back.
Ok, this is cool. Can you explain how you hook it up and mounted that? I've been looking for a clean way to add USB's to the back of the rear heater...
I just drilled a hole in the front and cut the rear metal with a cutting wheel. Then I connected it's to a BlueSeas fuse block. Done.
so are they easy to fit
Yes it's was. The only time consuming piece was the front radiator support. You have to drill the spot welds and remove the 4runner support and install a Tacoma radiator support. Everything is bolt on!
I could of left the 4runner support, but I would of have to cut/drill to fit the headlights/grille/fenders
cool its makes for cool look and what about where the fenders and the door meet do the body lines match real well and all that
What if I just want to run it to the stock box? Should work ok? I don't have enough stuff for separate fuse block.
The line's are matching just like the stock 4runner fenders match like it was supposed to be there.
Sweet it looks cool as hell ill have to see how the 2nd and 3rd gen body lines match up since they are a little different but i like it and might think about doing it
Pretty sure you can, just put a fuse before the end of the hot wire.
Lines are totally different between the 2nd and 3rd gen runners.
CoaterZ_FL
