my supercharged 4runner. headers full ex. 10psi. water meth injection
I added a bleeder valve for my throttle body coolant bypass. I had it
Just looped with a piece of hose before but I was getting a air bubble trapped so I decided to add this bleeder. Plus it looks cool haha. Here's a before pic and the finished pics.
Just some update pics of my engine the new catch can and red valve covers.
Thanks guys means a lot im always working on it at least 5 times a week 2 to 4 hours at a time. I will keep you updated next im re mounting my led duallys with some small mr16 hids in front and also mounting five 7 inch 55watt hids on the roof.
Heres what I been working on these past weeks it took a lot of work and R an D I would say probably around 30 hours to complete. They are 7 inch 55 watt hids 4 spot 1 flood total lumens is 22,500. I will post up some pics of them on in the night once I finish up the wiring. Just in time for my camping trip in the forest :)
Pics
More pics
Added a skid plate for my engine oil cooler I noticed sand getting shoved into the lower portion of the cooler after I would nose dive off some steep dunes. It's just some 2 inch angel iron drilles out for a little air flow mostly cosmetic.
I got my 4 rigid industries duallys mounted they are 2 spot 2 flood also some trail tech mrm16 hids 1 spot 1 flood. Here's a pic of everything on together it's ridiculous how bright it is!
My crazy looking battery tray I made. My reason for relocating it is because I need the space for a overflow bootle fuze box and my relays set up nice and clean also for weight distribution. I mounted it above the wheel well so I wouldn't loose Any rear space for when I go camping I use it a lot to sleep in. This project took forever because of all the holes I had to drill! Haha
Here's my led interior project im working on so far this is all I have done the meth injection back light and amber under led. Can't wait to post up more pics of the other lights. I will be doing 1 switch will control the meth tank back light the amber under glow and 4 top mounted amber. Second switch will control 5 white leds 2 stock location 3 on the door and the reverse light led bulbs will be switched same switch.
What size nozzle are you using on the meth injection at 10psi? I've been at 7psi on the turbo for a couple of years now, time to step it up. Fab work and rig looks great by the way.
cremebrulady
