Nokian hakkapeliita 5 vs. Firestone winterforce
And the frosty mornings
The thing that gets me about the Nokians is that the 5's are made at a plant in Russia, at least a good number of them that I have seen were. I thought Russia was supposed to be a low cost producer?
They raised the prices after Sarah Palin said that she could see Russia from her kitchen window.
Nice choice AK man! The BEAST is now properly outfitted for winter. I chose not to get mine studded. From what I've read the studs are called Bear Claw's and are really designed to bite, yet ride quiet due to a cushion in the stud pocket.
Indeed they do and the square pattern says it enhances the bite. smooth on the drive home without snow a little firmer than the Pirellis. Sometimes I get call in the middle of the night and I have to be able to get there.:boxer:
We got our first significant snowfall in the last few days, then the temperature warmed up and the snow melted then froze when the sun went down. The Hakas are remarkable. When other cars were spinning good tires at stops these kept on truckin. Lots of stability. They seem to "tighten up" when the going gets cold ride feels firmer. Easily outperform the Pirellis (the tire pro calls them "summer tires").
Worth the money. *as I eat potatoes and cheese for a week. :thumb3::thumb3:
Kinda vagabond. RNs can basically get a position anywhere so I have found myself in the Navajo L.A. Minnesota and points east and west. Raised my kids in the SF bay area.
Do you expect to stay in Alaska long term?
When I was younger I lived in Wasilla for a few months...
Big Snow.
Turkey day 1 day after. Big snow here in Anchorage Eagle River area..........so far about 7 inches and still comin' heavy. So naturally I got the Beast and the Hakka's out for a test drive.
Here is the detailed and formal report.
Amazing Tires
How do the studded tires compare to studless (but true winter) tires on snow and ice-free pavement? Is there any drawback?
On days when the road is free of snow it is still surprisingly icy at the temperatures we have here. that said running in 2WD an option and the Nokians do well, noisy and the drawback is obvious that you eat your studs.
This tire IMO is good choice for a location where you are going to get snow for several months at least and you have to be ready. I ran Pirelli Scorpion ATR in Anchorage last year. They performed well, but nowhere near the competence of the Nokians. The Hakka's simply adhere to pavement.
Next test will be when the sun comes out in a few days, thinks cool down and ice is on the roads. I got these, as the Scorpions like most AT tires don't do ice as well as studs I have heard.
Called the dealer. He will take a look at them and adjust if needed. thanks for watching my back...........good to know. by the way as predicted rain came turned the snow to ice and the Hakka's did great. 80% better than the Scorpions on the real slick glass ice.
This post did not appear on the site but I am cut/pasteing it on.....?
Alaskaman, your right front tire is rotating the wrong direction. See those arrows on the sidewall. The Hak 5 is a directional tire and only gets its best traction turning in that direction. Your left front is correct. I can't see your back tires in the pictures. If you're lucky, your left rear is going in the wrong direction too and you can just switch your left rear with the right front. If not, the dealer should switch the tire on the rim and rebalance it for free because it's their mistake. Look at both back tires. They may have mounted all 4 the same way on the rims. Hak 5's must have 2 mounted one way on the rims and the other 2 the opposite way on the rims. Rotating the wrong way probably won't affect wear, just traction. In deep snow, your left side will be pulling better than the right side. Could cause a spin out I suppose. Unlikely though with those tires. On ice should be almost equal because of the studs. Although Hak 5 studs are supposedly pointed in the direction it's rotating. I can't confirm that. Either way it's better to get it going in the right direction.
Talked with the dealer Anthony and he tells me that all 4 tires need to be directional in the same direction. the arrows on the 2 front tires and the 2 rear tires are all going in the same direction. not sure what you are seeing on the right front which you said was not mounted correctly?? as to mounting he says no. do you have any links to support your information? Appreciated.
so JPAnthony.......not sure why you post did not show up on my computer yet.........had a chat with the manager he said he had never heard of mounting 2 one way and 2 the other......anyway........stop smoking that crap. it makes you crazy ya know? :whipping2
I saw his post, and by the time I replied to it, it was gone. He must have realized he was mistaken and deleted his post. I deleted my reply when I saw his post was gone. When I looked at your pics the tires looked fine.
I know what he means though. Some tires should only rotate in one direction because of their tread pattern. Yours might be like that, but they look correct.
