***northstar deep cycle battery group buy***
not trying to be difficult, but looking at the test results posted:
Even with the group buy discount, it would be cheaper to go with a die hard platinum for about equal performance.
Am i missing something here?
You are correct.
Here is the thing:
A lot of the peeps on TW are having a hard time getting diehard for the Tacos. Why? I don't know. Therefore, diehard is out of the question for now.
Optima won't do group buys, plus a lot of people don't like optima.
Excide never replied to my emails, plus a lot of people don't know excide (I am a proud owner of excide batteries)
Odyssey ignored me, even tho some people wanted odyssey
Diehard wasn't interested, even tho some people wanted diehard
So who is left on a group buy? Northstar, they agreed on doing this and went ahead and made an offer.
If you are able to get a diehard and feel happy with it, go for it bud. I was just throwing these numbers here on T4R just to see if anyone would be interested in this.:becky:
I'm not trying to kill this group buy, just inform, but rebranded Northstar (X2Power) come with a longer 60 month warranty, are easy to get warranted, and cheaper than the Northstar, and even than this group buy.
X2Power batteries from Batteries Plus are the equivalent to the Diehard platinum batteries for Odyssey.
Their current prices (after a $30 mail in rebate):
24- $249.99
27- $274.99
35- $234.99
You can take 10% off the purchase price if you use code CDP10011 (Expires 12/31/15, but is usually replaced) online, and pickup in store.
Tax would be extra, but the 10% should cover tax for most, plus a little discount left over, and you have to pick up in store.
If I'm out of line posting this, let me know, I will remove it.
I don't mind. Ill leave it up to everyone to do their own research. Some people don't like rebranded batteries. Just a matter of who wants what.
I usually take suggestions on prices and brands per PM and let others do their research on brands, rebrands, etc.
If I started searching for each one of these rebranded companies, it would take forever to find a good rebrand, reviews, contacting vendors, prices, etc.
If those people are buying Diehard Platinum batteries, tell them they are re-branded Odyssey's. :roll:
Do you have any specifics regarding the battery you're talking about? The term "deep cycle" is often thrown around a lot incorrectly ( not saying you are at all). From my understanding, true deep cycle batteries do not make for good automotive batteries as they have much lower cranking amp abilities (but excellent draining/recharging abilities)
The Northstar batteries in the group buy, and also Odyssey batteries are an exception to this general rule. Both of these are closer to military grade batteries.
They use a high-quality, purer lead, and many thin cells with the "AGM" (absorbent glass mat -- I believe) materials between the plates.
Then they take this multi-layered "sandwich" of sorts, and compress it to fit in a much smaller the space.
The results are really good....
The batteries are very dense. The Odyssey batteries that I own weigh almost twice as much as similarly sized lead-acid batteries!
The have a large surface area for the plates (which means they can deliver very high current loads), and because of the materials and their structure, they handle deep discharge and recycling very well with minimal distortion to the cell structure and minimal sulfication or other problems with deposits.
The batteries also tend to have a longer service life if properly maintained.
They also have a very low self-discharge rate. For example, a new Odyssey battery at 100% charge can be left sitting unconnected for 2 years, and will still
have about 80% of its charge.
I'm sure that the stats are similar for the Northstar batteries. You should consider Northstar batteries essentially the same as Odyssey... (although the ARE different companies).
So with these batteries, imho, all you get are benefits. There are no negatives.
They serve equally well as starting and deep cycle batteries (despite the fact that many "lesser" batteries need to be designed for one use or the other, but can't and don't do well at both), they offer a substantially lower self-discharge rate, and they offer the promise of a longer service life.
So, what are the negatives? Only two that I'm aware of... and they both depend on perspective:
1) They are expensive. You can pay much less for a battery.
2) They are heavy. If weight is a concern. These batteries are heavy.
on the flip side, if weight is a concern, you may be able to buy a
smaller than recommended battery, save on space and weight, and
still get acceptable performance.
I hope this answers your question [MENTION=125277]jahmes143[/MENTION] .
The batteries in this group buy (and a few similarly made batteries) truly are exceptional, and the standard rules and logic about most batteries don't apply to these. With that said. They still are batteries... meaning, if you buy one of these batteries that is rated at 135 amp-hr reserve capacity... that is about the reserve capacity that you will get, and it will die and need to be recharged after you have used up that capacity.
You won't magically find that you somehow get twice that reserve capacity.
How do I know... let's just say that once I ran too many accessories on my boat for too long, thinking that I had "super batteries" on board, so I was invincible!
When the batteries were dead, and I had to scramble to get the boat started, I realized that they are still batteries. Very, very good batteries, but none the less, they don't bestow magical powers that mean they can't be run down.
On the other hand, at the end of the season, I make sure they are charged, turn of the battery switches, and in the spring I'm fine. All batteries have a good charge, and I am good to go. No need for a trickle charge or to periodically recharge them during storage.
I *might* be better to take them indoors over the winter, but I don't bother. They're too heavy to deal with!
:usa2:
Good luck to anyone who signs up.
I don't need batteries, but I thought I would share my knowledge and experience with these types of batteries.
I have these (or similar technology... but different brands) in all of my toys.
My 4Runner, my wife's Benz, my convertible, and THREE of them in my boat (2 for house batteries, and 1 for a starting battery).
After more than 8+ years of experience with these, I am 100% completely sold that this is the best way to go. You may (or may not) save money over the long haul when compared to buying cheaper and regular lead-acid batteries.
But, you WILL get better performance out of these, and you WON'T have as many problems of them dying, needing to be recharged or be replaced as frequently.
As for Optima batteries. I had one Red Top, and it was good, but it didn't last as long as these other types of batteries lasted. I have heard rumors that not all optima batteries are the same. That some sold at some discount chains are actually made with cheaper materials and weigh much less. I don't know if the rumors are true. My Optima experience was good... but these "super batteries" as I'll call them here, are better.
-Phil
i am most likely in
I am most likely in.
I will probably be in for
24F qty 1
35 qty 1
i am still trying to figure out what my 2nd battery tray will hold.
Just bored and researching*Northstar*and came*across*this
https://youtu.be/16ShlFunpws
Another good thing for those on the limb, they use 100% pure lead unlike other brands that use recycled lead.
Also, here's a very detailed and informative video about how Odyssey batteries
are made and what is different about these type of AGM batteries.
Each battery is made of many 99.99% pure led plates that are 1mm thick and perforated to create a very dense, very high surface area battery.
I'm including this video in SUPPORT of the group buy. Northstar batteries should be just as good if not better than Odyssey batteries. Northstar was started by former Odyssey insiders.
So while I don't know the specifics in the differences between the two brands, as a consumer, you should really consider the two brands as equivalent.
These are definitely the best available.
-Philip
P.S. -- I have no dog in this fight... so to speak. I don't need any batteries now, and I don't get anything from the group buy. I just thought I'd help share this
info with other members on the forum.
For what it's worth, Northstar and Optima are the only high tech mfg's that make the 24F size.
I know other sizes will fit but for those looking for oem size there ya go.
At least I couldn't find any of the odyssey/sears in 24F.
Watching this GB.
:usa2:
-Phil
Thanks for this bud! Can I use this on TW?
24F qty 1
35 qty 1
Ill add you for TWO bud ;). Let me know if you get a third
-Philip
and this?
Watching this GB.
Do eetttt
Looks like we are slowly gaining traction! List updated!
1. [MENTION=3036]Wheelin[/MENTION]TheSky
2. [MENTION=3036]Wheelin[/MENTION]TheSky
3. [MENTION=123666]Tretiak30[/MENTION]
4. @Mph6779
5. [MENTION=5459]heavy[/MENTION]Thumbs
6. [MENTION=133981]jmf_tracy[/MENTION] (T4R.org)
7. [MENTION=133981]jmf_tracy[/MENTION] (T4R.org)
8. @Digiratus
9. @FrustrationFabTaco
10. [MENTION=67155]qnyla[/MENTION]
11. @ppham444
12. @EDDO
13. @Rhubarb
I am going to have to pass for this reason. Thanks though.
You're missing the fact that DieHard doesn't make the Platinum line anymore and if you buy from a place that isn't a dealer (like amazon, ebay, or someone NOT on their dealer list) you void your warranty.
Not trying to deter anyone away from this GB. Northstar still makes a very good battery. Not everyone needs a super duper battery that withstands a punch from the Incredible Hulk. But if you want a high performance, higher $$ battery, go with an Odyssey (now that DH Platinums are no longer made)
http://www.odysseybattery.com/extreme_battery_specs.aspx
yes, i have since found that out.
I am already on the list for 2 batteries.
Extreme Series Battery Specifications ? ODYSSEY battery
Not sure why I was quoted in this post. I chose not to go with the group buy as there is no local support for warranty. I would have to shop the battery back to this particular distributor. Something I would rather not have to do.
As far as the Diehard Platinum, was there an article you saw stating they no longer provide this line? I still see them available both on the sears site as well as the Diehard site DieHard | Car Batteries
Diehard doesn't make the Platinum line anyway, they are produced by Odyssey, and have been for years.
Just a little confused on this post.
youngrk
