Okie's 2003 4Runner build
Oh, and I pulled the trigger on a Toytec ultimate lift kit today (thanks to the 10% off customer appreciation code). Quite the productive day.
...I also ran the USB input down through the console (for Apple Car Play). Is there a special USB adapter I could put into the button slot to make it look nicer? I browsed Ebay but couldn't find a male-to-female interface.
https://www.amazon.com/gp/product/B...fl_title_40?ie=UTF8&psc=1&smid=A15H3UKRB6RHF9
I found this a while back on amazon. I decided not to get it because I prefer Bluetooth wireless over the wired. one less wire to deal with.
^^ that would work if you want to use that slot. I don't use apple car play, but I routed my usb with a music drive to the inside of the console in the slot where the auxillary plug was located. I originally replaced the insert with a factory usb/aux plug to keep a stock look (in the picture), but my connections weren't the greatest (you have to create a male-female end by taking apart an adapter) and it would restart the usb everytime I hit a bump. I have since then just did what you did and fished the female end through the empty slot inside.
a4bd8c31-5e4d-4abd-8be6-4ad68760e7be.jpg~original
Installation took most of the day today. Pretty straightforward though, and I'm very happy with the end-product.
Before:
93518406-E6E0-40C8-A617-16611E9DAF9F.jpg~original
46B8070F-CF8D-4856-BB7A-026B327901A1_1.jpg~original
After:
DF4CEE2A-01C4-4E54-8431-F5F139A19EF2_1.jpg~original
271D938C-8324-494F-896E-BD814EF8B47F_1.jpg~original
From the looks of it, I may need to bring the front in down about an inch. Think I'll let it settle before I make any changes.
A few installation notes:
1) PB blaster saved the day! This truck had spent some time on the California coast and all the nuts/bolts show it.
2) Sway bar links were shot so I left it off until I can get new ones. Thinking about replacing the swivel-type links.
3) Broke a bolt off installing the rear bumper extension. Didn't feel like spending an hour trying to fish it out so I put the bump stop extension in with one bolt until I think of something in the meantime.
85600941-B23B-4DD7-B614-93ABB08ABAAB_1.jpg~original
4) Front fit in nicely, again thanks to a lot of PB blaster beforehand:
623A5D0E-5E14-45BB-81EE-284CE224C2CF_1.jpg~original
5) Doing this by myself sucked. Having a second set of hands would've been nice, but more importantly it's always fun to undergo a project like this with a buddy.
Swapped out the interior bulbs for LED's from Amazon.com.
IMG_2926.jpg~original
Replaced map lights (2) dome light (2), cargo light (1) and door lights (4). There's one extra bulb of this 10-piece kit that I can't account for.
...even my head mechanic was stumped!
IMG_2925.jpg~original
You'll be begging for UCA once you realize what a stiff ride it is lol
Anything is better than before; the shocks were shot. I've considered aftermarket UCA's but the alignment is fine and it the ride is nice. Maybe I don't know what I'm missing though.
New rotors and pads all around this morning. The back was cake, but the front had TWO frozen calipers:
IMG_4022.jpg~original
...So new calipers as well. Drivers side and passenger side are different colors though, is that normal?
IMG_4016.jpg~original
Brakes are still a tad squishy, has anyone had any luck with re-bleeding to help with the plush pedal?
UPDATE: With a little help from the spouse, I was able to bleed-out an additional amount of air from the brake lines. Much better now.
The sub on my JBL system has been blown for a long time now, making that embarrassing rattle whether it's hip-hop or rock-n-roll. I picked up the Rockford Fosgate P3SD2-8 only because of its Amazon reviews (yeah, too lazy to do too much research).
Accessing the subwoofer wasn't too difficult, although I was able to break-off one of the cargo net holders. Two write-ups mentioned that it simply popped out. Well it didn't and I was left with a eyesore, so I put a USB charger in it's place:
IMG_4645.jpg~original
Not sure what I'll use it for, maybe camping?
