Post your LIFTED pix here!
Stoked!
3" Eibach Pro Truck Shocks/Coils, SPC UCAs, 285/70R17 KM2s on 17x9 Pro Comp Vertigo wheels. Rides and looks awesome!
A few more
i hate how i have to leave a message just to post some pictures..
5 months of upgrades and loving every minute!
My 2011 doing what I bought it for.
I’ve got to say, upgrading the tires from the 265’s on stock 17x7 to 285’s on 17x8 made a huge difference, especially while loaded up w/ men & gear.
JD
Got the runner back today with IVD suspension upgrades, rides and looks better a little taller. The front came up 2 inches and the backed got raised about an inch. Once the springs settle down it should just be slightly taller in back for towing our teardrop.
Top stock, bottom lifted:
upclose...purdy..
Love the results and the crew at SDHQ was awesome!
Now for nicer wheels and some 285's:loco:
I can finally post!!
Bilsteins 5100's all arounf OME 885 fronts and SAW 1.5" in the rear. Bilsteins set at 0
Here's a before and after
Icon stage II
Got it installed this afternoon. Drives so smooth. Should get my tires mounted friday. Getting 285/70/17 trail grapplers.
anyone know why my suspension has been rising instead of settling? I installed 5100s with OME 885s and SAW 1.5" in the back. I have driven about 250 miles since installing the new suspension.
My rear springs haven't settled at all which is fine. But my fronts have risen about an inch since the last time i measured.
Ive been measuring the floor to the middle of the wheel well each time on level ground. I don't mind the extra height, i like how it looks now that it's been raised a bit but I'm just curious why its rising?
I'm not sure why it would be rising... but try measuring from the center of your wheel to the bottom of your fender.
For all the DIY guys, how long is the suspension install taking for you all? Trying to see if I can manage the install with one friend.
I have installed suspension on sports cars, so it would seem this is very similar but I figured I'd ask you all first.
Local shop asked for $500 including an alignment, so I'm weighing the cost/benefit of doing it myself.
I'm sorry I'm unable to answer your question but I do have a question for you. Exactly what does that quote entail? What all are they installing for you?
Took about 3 hours using the "no spring compressor" method. And that was with the hassle of KDSS as well as ample beer breaks. You should have no problem.
The quote was for:
Install 5160 & 6112 Combo $400
Alignment $100
No UCA's or any other parts.
Installing myself is fine, but on jobs like this I'm always missing some stupid unicorn tool that's needed for this one job only or I break something haha.
Which front lift did you install? Did you disconnect the upper control arm and slide the assembly in and out that way instead of disconnecting the lower control arm?
AndiGarage
