Post your LIFTED pix here!
14 Trail Premium w/ KDSS. BOSS Suspension , 285 Nittos
So I'm new to the 4Runner world but have always had lifted trucks. All I can find are either custom tall lifts or bolt on 3"... Are there no options bigger than 3" ????
rims/ tires clearance
I'am getting ready to mount BFG K02 285/70r17 tires on my SR8 rims
Bolt Pattern: 6x139.7
Backspacing: 4.30"
Offset: -10mm
Weight: 24lbs
Hubcentric: Yes
Max load: 2100lbs
What i wanna know is what modification i have to do to the front fender wells to make it work...i have a 3inch lift and would like to keep my 1.25 wheel spacers on..
Backspacing: 4.30"
Offset: -10mm
Weight: 24lbs
Hubcentric: Yes
Max load: 2100lbs
my buddy of mind has bilstien/toytec 3" and he recently installed his stealth wheels F5s with the same wheel specs as yours and added spidertrax 1.25 wheel spacers and he had to cut alot from his fenderliner and cut his lower front bumper and do a body mount chop he was rubbing real bad.
Here's our 2016 Trail.
3" lift:
Icon 2.5 Coil Over Front struts
Icon upper A-Arms
Fox 2.0 Resevoir Rear shocks
Icon Rear Coils
Icon Rear Trac Bar
BFG All Terrain KO2 285/70R17
TRD 17" black wheels
and more.
Backspacing: 4.30"
Offset: -10mm
Weight: 24lbs
Hubcentric: Yes
Max load: 2100lbs
Just installed wheels with same specs, but no wheelspacers . . . lots of rubbing here . . . moved fender liner forward and will probably have to remove front mud flaps . . . assuming BMC and bumper trimming on your end
Looks sick bro!! I'am just going to leave the spacers off for now. Can you take pics of your front bumper trim so i can do mines ahead of time... Hawaii FTW!!!
Talyn
