Post your LIFTED pix here!
King coil overs and upgraded springs, about 2" lift:
Ok everyone here is my lift. Bilstein 5100 all around. Front at 1.75 rears are 1 inch cornfed spacer. Rims are Gunner Black 275/55/20 grappler g2
Simple Level Kit (for now)
New wheels and tires thrown on yesterday. Totally transformed the look.
2.5/1.5 spacer lift? Wheel/tire specs?
I'm not the person you asked but I recently did upgrades on my LE so I'm replying.
Icon stage 1 (stage 2 soon I think)
Icon six speed wheels
Toyo open country RT 285/75/17
Sent from my Pixel using Tapatalk
Is that a lotus??
Actually an Alfa Romeo 4C. Gets confused for a Lotus often. Much more comfortable than an Exige I had previously, but its still as good (probably slightly better) performance-wise. The Lotus was extremely raw!
Correct. Just the simple Daystar 2.5/1.5 spacer setup. Picked it up on Amazon for ~$130, and my indie shop had in installed in 1.5 hours. About the only way to go with the XREAS setup and still keep it in place. I may eventually go bigger with a full blown ICON lift one day, but this works for now on the cheap.
Helo 18x9 wheels with Cooper Discoverer STT Pro 285/65/18 tires.
Your limited looks awesome. Well done. [emoji122]
Sent from my SM-G920V using Tapatalk
I have a question about tire size. I'm installing the toyotec 2 in lift on my trdpro. Will 285/75/17 fit. Or is it better to use 285/70/17? Thanks for all the help.
My experience with my stock SR5 wheels, which are 17 7.5's, I've fit 285/75/17s in BFG KO2 and I don't experience any rub. If I used spacers I'm sure I'd need to do a BMC. Fargo4x4 runs the same setup (but they use spacers) and it is tried and true through their adventures.
Sent from my Nexus 6P using Tapatalk
I have about 2.75" of lift up front and I have the TRD wheels. My 285/70/17 BFG KO2's rub almost never. Just a little on the front fender liner occasionally (haven't felt the need to mod).
Every truck is slightly different, but there's a good chance that 285/75/17 tires would require some modifications to the front fender, remove mud flaps, possible body mount chop, etc.
Icon Stage 6 + Icon 3" overland rear springs + Timbren Active Offroad bumpstops
Awesome! My dad had a 1969 Alfa Duetto Spider. I leaned to drive 5sp on that car!! Always loved Alfa cars.
