Radio Upgrades... Let see them.
Does anyone have a recommendation for a non JBL 4R? I'm not really interested in bells and whistles as it relates to android or Apple phone integration. Most of the time I'm using my truck I won't have a cell signal. I'm interested in GPS/Bluetooth/tuner. Thanks guys!
DNX996XR is the king of radios right now.
OK, the Alpine ILX-W650 I listed above is going back.
I called tech support about the static on the phone while using android auto and they said to update the firmware. I did that and it is still there. As soon as I unplug the USB for android auto, the sound is fine. Phone calls are over bluetooth so not sure why plugging it in and running maps on android auto would have any effect on the phone call. However, a quick google search shows that this is not uncommon with other phones/car setups.
With that said, these are listed as fitting on Crutchfields site
$345 Pioneer AVH-2550NEX DVD receiver
I like the hard buttons for volume. Has dvd/cd player too (if anyone uses those anymore). Looks OEM.
$348 Sony XAV-AX5000 Digital multimedia receiver
Hard buttons again. No cd player so it's smaller behind screen.
$349 Kenwood Excelon DMX706S Digital multimedia receiver
Hard buttons, big screen.
It looks like I can get into wireless Android auto for an extra $100. Not sure that's worth the price since it'll likely drain the battery anyways and have to be plugged in to charge.
I don’t understand why you would be using Bluetooth at all if hooked to Android auto (maybe this is the source of your problem?) I don’t have an Android, but my Sony XAV-AX5000 supports CarPlay and Android auto. I use CarPlay because I have an iPhone. Anyway, if I’m plugged in to CarPlay, Bluetooth doesn’t work, nor does it need to. CarPlay completely syncs everything with the phone for calls, music, navigation, etc. The only time Bluetooth gets used for calls, or music is when I’m NOT plugged into CarPlay. Phone calls and other functions are way clearer when direct connected with CarPlay so I never use Bluetooth unless I’m driving a very short distance and don’t want to plug/unplug the phone. Doesn’t Android auto function the same as CarPlay? All I know is I’m super happy with the sound and functionality of my Sony.
Just bought the AX5000 from Crutchfield, should arrive this week! Super stoked to get some CarPlay action as I’ve gotten quite used to it on my newer car.
You are right. Bluetooth is not being used when plugged in for AA or ACP.
More than likely a problem with Android Auto rather than the radio.
We have sooooo many problems with customers androids working with android auto after a new radio install.
Apple Car Play works every. Single. Time.
I would go with the kenwood DMX706S or the DMX906S if you want wireless. The wireless AA tends to work better than being plugged in. Androids have to many needed and changing USB “handshakes” to make it really reliable.
I have no idea how it works. If I am on the phone without USB plugged in, it has to be BT. If I plug USB in, does it switch off the BT? Don't they go hand in hand? I am pretty sure I couldn't run Android Auto unless I paired the phone via BT first.
I'll turn BT off and see if 1) the AA works, 2) If the phone works.
So calls are made through bluetooth with android auto. I turned off BT. Plugged in USB, plugged it into the radio and BT turned back on. I made a phone call, fuzzy while plugged in, fine when unplugged. Then I turned off BT while still on the phone through the radio (but still plugged in) and it dropped the call from the car.
Ok, after reading Evans post, I’ve come to one conclusion... Roy, you should probably keep the stereo, but dump the droid. Both platforms have their pros/cons (I’ve had both), but honestly, for data transfer and connectivity with music, video, and data, Apple is where it’s at inmo. Everything just works, and every product they make seamlessly integrates with zero fanfare/effort. Just depends what important to you, I guess. For me personally, I’ll never go back unless apple really f’s up somehow.
I don't see that happening any time soon. I was an early adopter of Iphones and got out around Iphone 4 or 5. Switched to the S4, then one of the Edge phones, and been in the Note lineup ever since.
Things I like about the Iphone- They are simple and everything seems to work.
Things I hate about the Iphone- Their proprietary BS- Cords, software, etc. Lack of adding memory to the phones. I have never needed to delete anything on my phone because of the sick amount of storage between the phone itself and the internal memory card. It's nearly impossible to upgrade/change iphones and move your information unless you have a degree in computer engineering. IMessage. I have missed so many texts from Iphone users because they are sending Imessages by mistake instead of text messages. They show up on another device that doesn't get used much.
I do have Ipads at home and run Ipads for all my work guys and they are great. I do haven an active Iphone in my X3M because they don't have support for AA :(. I only use it for the data/maps/carplay.
With that being said, tech support said to try a different USB into the back of the radio. I did that yesterday. Took the whole car apart, pulled the radio and plugged the USB directly into the back of the radio. SAME PROBLEM.
As I mentioned, both platforms have their pluses and minuses. One thing I’ve found to solve the memory issue you mentioned is I currently have a iPhone 7 with 128g. That would be a decent amount of storage on its own, but a few years ago, I was upgrading my iPad mini to a newer model, and didn’t have enough iCloud storage to easily transfer the data, and as you mentioned, it can be quite cumbersome trying to do it without a lot of technical expertise. After research, I decided to just pull the trigger on the upgraded cloud storage for $2.99 a month (basically the cost of a coffee). Not only did it make it super quick and simple to transfer everything over (it even used my same wallpaper so the new iPad looked identical to the old), but now I don’t even come close to using 1/4 of the 128g storage of my phone even with 2500 songs in my iTunes library, and 10’s of thousands of photos and videos. In short, I could easily function with an even SMALLER internal memory now! I recently had to send my phone back to Apple for a connectivity issue that was a known issue with some 7’s, so I used an 8 for a couple of weeks while they completely replaced not only the mother board, but also added a new battery, completely free of charge. Even switching the phones back and forth was completely seamless because of the iCloud backup. Other than the phones being different colors, EVERYTHING on the phone was retained identically from wallpaper to app arrangement. Not trying to sell you on Apple, but since you already have iPads I thought I’d mention this option, in case you were unaware of how it works, or how easy it is to use. Just as an aside, both my wife and daughter have the newer XR, but I chose to keep my 7, especially after it was rebuilt free of charge because it is smaller, which I prefer for pocket carry, and I’m not a fan of the lack of home button on the newer models.
I am not sure this classifies as a radio upgrade in the sense of replacement, but here is what I did on the cheap if you will. I had an old LG G-Pad 8" collecting dust. I thought this might be a great test bed for a simple android radio swap and how I would use WiFi tethered to my mobile phone. I downloaded an app called CarLauncher to give a radio look or feel to the interface. Honestly I barely use it as my primary use model is Waze and some music app (Pandora/Spotify). As far as making the unit "stick" in place I was able to use Neodymium magnets which worked with my factory Nav Touch Radio. Additionally I did make a custom Toyota wallpaper and minimized useful apps for driving for that home display.
Here is how it looks:
Car Launcher is app I tried:
Removable shot:
Phone mount for teathering WiFi:
Details on the RAM mount? And links please.
Removable shot:
Just bought a Sony XAV-AX100 on clearance. If I can decide on a backup camera I've got everything else I need in a shopping cart on Amazon. Hope to have it installed sometime next week.
Anybody have the Pioneer AVIC 8500NEX? I see its pretty discounted now because their new line of floating screens w/ Alexa are about to release. Wondering if I should take advantage or wait to see what the new line offers.
The 8500 is a great radio. The AVHW4500NEX is even cheaper if you don’t care about built in navigation.
The ones that are coming out now are just like you said big floating screens. Not much else new. If you don’t care for the big screen go with the older 4500 or 8500. Both great units.
Ive been running the atoto A6 for a little over a year now along with the Natika backup camera and heres my take:
The atoto a6:
Fits great in the oem spot, hence why i wanted it. Android auto with the dongle used to work great. Relatively plug and play with the steering wheel controls, i did have to modify the metra harness to get it all to work, but its great now that it does. The last few months ive had constant bluetooth issues, along with android auto always freezing. Now their customer service is awesome, they are quick to get back and try different solutions, theyve exchanged the android auto dongle twice because of my freezing issue. Theyve sent updates to alleviate my bluetooth and backup camera issues. However just yesterday the screen went dead and ive emailed them to let them know the issue. They gave me a solution to try and i will give it a shot. If not, i will probably be looking elsewhere which sucks because it is such and awesome radio when everything is working. This is just and fyi.
Thanks for the update on this. Was looking at this HU for when I eventually upgrade but I'll hold off for now. Let us know if it gets fixed or what you replace it with.
Got my Alpine ILK 650. Nothing fancy but it works. I made a call on bluetooth and plugged in and both calls were good.
Mic location is only temporary.
erinobr2000
