Rear Differential Breather Mod For Dummies
Here’s how I did the 3rd gen... might want to double check the diff nipple fits.
Routed up to the drivers taillight cavity
Fuel hose w/ clamps: $15
Fuel Hose 30R7 5/16" I.D. 7 Feet USA w/ 4 Clamps https://www.amazon.com/dp/B06XWQXYNY/ref=cm_sw_r_cp_api_i_eOa0Db5FATYJX
New breather: $8.50
Toyoya 90930-03136 PLUG, BREATHER https://www.amazon.com/dp/B01FSZ9YY4?ref=ppx_pop_mob_ap_share
Diff nipple to replace stock vent: $8
Genuine Toyota (90404-51319) Union https://www.amazon.com/dp/B00P2S0TKQ/ref=cm_sw_r_cp_api_i_TOa0DbTHCX79Q
Edit: gotta give mtbtim props for the Toyota part numbers in his YouTube tutorial. Thanks Tim!
Looking at options for a diff breather. I see that ToyTec offers a kit for $32 and the ARB one is double in price. Are there any other budget friendly options? I don’t plan on submerging the rear diff. This is more for piece of mind.
You could search for the individual parts that make up the Toytec kit to see if piecing it together yourself is cheaper than buying that kit.
[MENTION=105875]96r50[/MENTION] [MENTION=124959]Runn4est[/MENTION] [MENTION=153412]theShaytoon[/MENTION]
I liked the idea that yall did of running it up the gas filler line and keeping it behind the rear wheel well, planning on doing it to mine this weekend. Sounds pretty self-explanatory, but I wanted to check and see if anyone had a good picture of that before I go ahead with it just in case.
Thanks.
Are there any advantages/disadvantages to re routing the breather to the gas cap/gas door I've seen in other threads? Seems like much less work with similar outcome. Thanks!
Thanks.
I went up behind the fuel fill line and zip-tied the new breather line up there, but didn't take any photos. It's pretty straight forward once you get under there and look around -there's really no need for photos.
One thing I did end up doing was popping the rivets out in the wheel well off so those needed to be replaced when I was done - pulling that mud guard back really made getting things situated behind the fill tube easier. Local ACE hardware store had the replacement rivets for $.50ea. the entire project cost less than $10. (not counting chilled beverages consumed during the event)
this will work, no disadvantages. some people even just run it into the cabin near the jack (downside of this is potential odors)
[MENTION=368898]hatidua[/MENTION] thanks for the info, I still haven't gotten around to doing it yet but I'm definitely going this route now.
Had my buddy print me up a spacer so I could use the existing threaded holes on the fender, worked like a charm.
Sent from my R1 HD using Tapatalk
Sweet, can your buddy get more done. i would like one. i also dont want to tap into car. thanks
[MENTION=148258]elpete77[/MENTION] It's been a while but any chance you could have another one of those made? Definitely happy to pay and pay shipping. I have no connection to a 3d printer and like the look of that and the no drill aspect.
Anyone else have this ability? I could probably draw out measurements.
I second this?
How about a copy of the STL? I still haven't gotten around to installing mine, this would give me an excuse to fire up the old 3d printer.
Installed the ARB extension kit yesterday while working on my sliders. Install post linked below.
ARB Differential Breather Install
I should have picked a more traditional location along the sidewalls instead of the back of the firewall, but in the end, it works all the same. Just wasted time fishing the module out of the engine bay because of the weird angle I chose to install it on...
When inserting the hose into he shark bite valves is there always a loud audible "pop"? I had clean cuts when I trimmed my hose and went straight in, I did hear a loud pop but it felt like it grabbed, and it didn't come out.
I used to have an FJ and there was a scuba mod everyone seemed to do and I bought a kit from the forum member that sold these (no longer does).
FJNewb's SCUBA DRIVER Mod!! | Toyota FJ Cruiser Forum
I’m trying to figure out if this ARB kit covers all the breathers the FJ has. Since I have a 4Runner now figured this has been covered. I just want to make sure if one kit covers all breathers or I need more than one.
ghengiskhan
