GottaBeTRD
thats cool man, yeah id prefer something dimmer for that light. Those shocks look so sick! i cant wait to start piecing my lift together. i gotta stop spending on all this cosmetic stuff lol
Field Monitor:
1. Blue/Yellow wire coming off the female end of the White Plug, taps into the Gray wire coming off the Blue Plug. (full-time power)
2. White/Red wire coming off the female end of the White Plug, taps into the Red wire coming off the Blue Plug. (ignition power)
3. White/Black wire coming off the female end of the White Plug (this wire also could also be Gray), taps into the Black/Red wire coming off the Blue Plug. (GROUND)
Clock:
4. Green wire coming off the female end of the White Plug, taps into the Green # 3 wire on the back of the clock in the dash.
(I taped into the solid Green wire coming off the back of the dash light dimmer knob)
Temp Sensor:
5. Blue wire coming off the female end of the White Plug, connects to your Air Temp Sensor. (This Sensor needs to be installed behind the front bumper. It contains 2 wires. See next step for second wire connection.)
6. Yellow/Black wire coming off the female end of the White Plug connects to your Air Temp Sensor.
Speed Sensor:
7. Green/Orange wire coming off the female end of the White Plug, taps into the Grey/Blue wire located at the ABS Unit. (It will be the Grey wire with a Blue stripe on it at the ABS unit. You could also say it is the Blue wire with a Grey stripe on it.)
Thanks, dude! Can't wait to see your scanguage retrofit. That is sure a UNIQUE idea.Looks great dude...
Thanks!That's a great write-up....you should post it seperately so that it is more search-able for others who are doing the same swap you did! :trophy:
Thanks! Your write up was very helpful by the way!Welcome to the club...the FMU club that is!
Thanks! I appreciate that.Nice work, great looking truck too.
Thanks man! You also have quite a good looking 4runner. Thanks for the compliments.Great looking ride and great build thread too! Not sure how I missed this one. The field guide looks perfect too. Nice clean install.
Thanks!Great Build!
It's not that bad, looking back on it.so jealous of your field monitor unit. good job man i would be scared to death to do something like that.
Thanks for the info on the dome lights. I've tried using the "6 LED Super High Flux" ones from Autolumination in a few cars and they've only lasted like 3-4 Months each time... Guess its time for a change. Awesome 4Runner BTW!
