Scrap metal rack
IdRatherBe
I have a friend who is going to put together a rack for me. At first look the thing that has me hung up sending specs is the actual mount on the 4runner. Are there any legs,feet, bolt on mounts (whatever you call them) out there that you can weld to attach to your own rack. Any better suggestions from you guys that have done this already?
My buddy is in rig building, so his shop is fairly simple in that he can cut and weld, but no bending.
Thanks for any help.
There are 4 mounting points total, the aftermarket racks use the factor 4 and than normally have 2 feet at the front of the rack that just "rest" on the roof. I took off the covers to paint my rails but its been awhile. I don't recall there being any "mounts" to weld to I would assume you will need to make your own brackets for the new rack vs trying to attache a new rack to the factory brackets.
P.S. Crawl on your roof, pop the plastic covers over and take pictures
Yea, that's what I was afraid of. Its just a little more precision than I wanted to ask for on a 100% free favor made by the shop hands down time. I'll look to get up there today or tomorrow and check it out.
Basically he said he could take the general design of the GOBI Stealth and make it (just with straight bars rather than all the lovely curved corners).
I've searched this forum and Google to find any good options, but it looks like everybody just manages to make their own bracket.
Well done, sir. That looks really good. I will be referencing the hell out that thread. Any regrets or do-overs you would share that aren't in the thread? It sounds like the fairing really gave a you a hard time relatively speaking. I wonder if I might just buy a fairing so long as it is wide enough.
Do the bent bars have any perks other than looks?
Factory bracket photo. Aluminum or steel?
1- If I could do it again I would have welding the floor in at the same time, just have to grind the coating off in a few places and weld the mesh in then recoating it, I just didn't feel like spending money on the extruded sheet then.
2- I wish I would have bought all my lights(one 32'' in the front, 2- 8" in the back, and a 12" on each side) and made brackets for them at the same time. but I didn't feel like dropping around $700 on lights then, and still don't, that's why I still don't have lights haha.
the fairing took so long because I was trying to make it so I could run my light under it and not on top, but gave in and just did the normal fairing and I will run my light on top like everyone else. and I thought about just buying a fairing and thought what if it doesn't work because its not designed to work with my rack.
if you are talking about the front corners(bent bars) I did them just for the looks.
if I make another rack, which im thinking of making a flat utility rack, ill have all the corners squared off.
a friend of a friend has a fabrication shop and he said if I give him plans he could pump out all the pieces for me and I could weld them together, but hes talking like making 20-30 racks and selling them, not sure if I want to get into the roof rack biz haha.
cover is plastic, bar and mount are aluminum. I thought about using the factory mounts but the aluminum shut me down.
