Tire Shops what the f_g!
96RedRunner
Senior Member
Bought set of 5 Stars this past Saturday have them ready to swap out to current tires I've been running 5/8" tread depth.
4 shops said no can't do it industry has gotten away from swapping used tires,or doing work on aftermarket rims,
older OE rims.
Money grubbing lying bastids. Happening where your at?
older OE rims.
Where in The Land of the Free is that happening?
older OE rims.
I can see that there's some form of liability in it for a shop, but I think they would have said so. "Hey, we'd love to do 'this' for you, but because the tires are used we, due to liabilities, cannot." I don't think they were necessarily being money grubbing lying bastards, but they also didn't provide you with a full explanation.
As [MENTION=643492]JustTroItIn[/MENTION] said, if you have a small mom-and-pop place, or like around me we have all these places that specialize in used wheels and tires, just have them do it. I had a set changed out for something like $100 a few years ago.
Must not be discount tire. Beacuse they mounted mine without a care. but i don't go there anymore because they put all the swollen lugs back on my Avalon and didn't say shit. Took me 3 hours to hammer every last one of them off.
LOL. They had the torque setting on "send it!" mode on those lugs.
I seen places actually snap lug studs off. Before. On air impacts you can use torque sticks ... on electric impacts don't torque with those ever. Use an actual torque wrench to the proper torque value. As electric can not torque properly at all...:(
GM uses those same capped lug nuts that love to change sizes. I have a 22.5mm and 19.5mm socket just for the swollen ones.
I've had tire shops cross thread the lugs on all 4 wheels. I had another put 2 of the lug covers on with a hammer, smashing them enough to be bent but not from outward appearances when stopped. I've had Discount Tire give me a good price on tires, then charge me an arm and a leg for new valve stems. A guy from a repair shop comes in (while I'm standing at the DT counter) and asks for stems. The DT guy sells them to him for a buck apiece... then looks at me. I said 'I won't ever be back at a DT'.
All these shops will cheat you, even the dealerships, given the chance.
Found out some background on this chit, it is about the money.
Shortage of workers only so many hours in a week take only jobs that make the most money,
Mavis Firestone Gateway Big Ten all within 2 miles of house.
Went to Truck 4x4 shop 10 mi away sure no problem, make appointment they all short handed. Place told what's going on.
Like the rest of you and stories never trust nobody when it comes to lug nuts been burnt myself.
I'll retorque my stuff when back at house hope they don't screw up either set of wheels.
Try a mom and pop tire shop. Big chain stores are useless.
Yup, a ma and pa shop is the way to go. I've had my local shop swap so many used tires around for me that they know me by name now lol. Plus they only charged $5/tire, $20/tire if they were disposing it. It was way cheaper than any chain place I went to.
Not Quite. Toyota has been using a 2piece "capped" lug nut. It's a 20.5mm nut, with a 21mm chromed sheetmetal cover. They are dissimilar metals, so over time the outer layer swells, making it impossible to get a 21mm lug wrench on without a lot of cursing and hammering...
Oh I see now. That's interesting. It's a good thing to know though. Sure, they "look good", but functionally they are "inferior".
Good to know if anyone is ever replacing their lugnuts. Don't get capped, especially if you're going to be in a situation where you have to change a wheel off-road, in the snow or mud.
If it's only a single speed for sure but if you have low speed settings it should work okay. My Hercules gun maybe puts 50lbs of force on the lowest setting with just an ugga no dugga. Then I just come back and get it up to spec with the torque wrench.
as noted, liability. my local independent shop says they will no longer install customer supplied parts. they said a customer took them to court over some sort of brake failure with parts he supplied. i think the parts were not quite correct.
anyway, between getting sued, and having cars stuck on a lift because the parts are wrong, they are saying no. sure there will be exceptions for special cases, or maybe OE parts.
I just take my wheels and tires off and take them to a local shop, costs me maybe $20 to have them swapped then I just give away the old ones. My local shop would probably mount and balance a potato if I asked him to, I’d bet half the tire business around here is mounting nearly bald used tires on newer diesel trucks
I had a Costco higher up tire guy say to me, who mounted your 265-70-16. I told him Costco mounted the tire on my 16" 5 star rims.
He said they (Costco) shouldn't have done it because inside the door sticker spec is 15 inch rim. And your rim is aftermarket and Costco shouldn't have touched it.
I said look around, for the 3rd gen 4runners, and your see those rims on them as they come like that from the factory. He didn't believe me, but I knew better.
As I walked out to my 4r, another higher up tire guy comes running out apologizing for the guy. I told that guy your co worker really needs more education on his craft. Being on his level, he should know better.
I go to another Costco location, no issues.
