Hello Tony, can't thank you enough for these detailed posts and picts, I am getting ready to start my own this week, same way or format as you have been doing, Interior HU, Deadening BU camera, new leather seats, etc, your broken plastic panels and dash pieces have me somewhat concerned when I tackle mine , but with what you are providing..mistakes included really are helpful, thanks again this site is awesome ,
Glad to hear that this thread is of some help. It has been slow going as of late, but I should have the sound system installed this weekend. And, with Monday being a holiday, the seats will hopefully happen at that time... Best to you on your build AR.
With some pretty good rain the past couple of days, and more water in my Runner, until a tarp put a stop to that, not much has happened. Little things while sitting in front of the fireplace...
I did get the 1.5' male/male RCA cables today, finally. They look to be the perfect length, not to make for excessive clutter back there... I crimped those gold-plated butt connectors onto the amp speaker out wires (8) and connected the short 14 gauge front speaker wires to those which each will go about 3 feet to their respective cross-over boxes in the kick panel areas. I already slid heat shrink tubing to cover those butt connectors...
Began working on the wiring harness. Confusing stuff at times. Mike was quite helpful, so that made it easier...
Here is the harness provided by Pioneer for the HU. Those wires bunched-together to the left are the eight speaker wires, which will remain unused. I'm using the HU's RCA outs to the amp instead. So, I taped those unused wires together and put a little liquid tape on the ends of each. What remains are seven wires...
Green = parking brake, per the label. As I understand it, that is for the display, so that it should only operate when the parking brake is engaged (the truck not be driven). Since I plan to eventually output to the rear seats, I will attempt to defeat this well-intentioned safety feature. Apparently, grounding this green wire does the trick. Would appreciate confirmation...
Yellow/Black = mute, per the label. I need to read-up on what exactly that means...
Red = switch power, as stated by both Metra and Scosche.
Yellow = constant power, for memory, per Metra and Scosche.
Blue/White = system remote control, per the label. This seems to not be a wire for connection purposes, but to receive signals from the remote control. Again, need to read...
Orange/White = illumination and/or dimmer, per Metra and Scosche. Do we have factory dimming on the HU?
Purple/White = reverse gear signal input, per the label. I imagine this must be for the back-up camera.
Black = ground, per Metra and Scosche.
Now, the Metra adaptors. Two are included as two are or were connected to our factory amp. The smaller adaptor on the right has four wires, for the rear speakers (a green pair, and purple pair). Those also are taped and have liquid tape applied to the ends. Basically, I won't even use this adaptor as there are no wires being used in this application; unless I did something wrong...
On the larger Metra adaptor, similarly, the four wires grouped together to the right are for the front speakers (white and grey pairs). So, from the Metra adaptors I a left with five wires.
Orange/White
Yellow
Red
Black
Blue = power antenna, per Metra and Scosche.
Hmmm... Some of these wires seemingly don't have dance partners. Those with more experience on such matters, I welcome your input.
