TonyB66
The manual radiator and auto radiator are basically identical externally except the manual one doesn't have the tranny cooler line fittings. The plastic just goes across.
I also have a champion I havent installed yet. Not sure which runner to put it in.
Mark, thanks for the follow-up here from that tranny thread. With no auto tranny plumbing at the bottom of your manual's radiator, maybe the innards are different too. If the capacity is more than the auto's radiator, that would seem to confirm it. A "bigger" radiator with more capacity and surface area would be nice...
Note to myself regarding rear sway bar end links:
Diameter of opening for top mount = 14mm or .55"
Inside width of that bracket = 41mm or 1.61"
I am contemplating:
1/2" grade 8 bolts, 8-10" in length (2)
1/2" Heim/rod-ends (2)
1/2" ID (a tad bigger) sleeves/spacers/bushings, 4" long (2)
Corresponding nuts and washers
Sway bar thickness where secured = 6mm or .24"
Anyone have a good place to find these sleeves? My web searches have not been all that productive... I believe due to the search terms used.
I'd make use of the ES poly bushings, jut bore them out a little...
