4RunnerTina
Yea the gearing on the 4runner is Sh..T! I have found my truck either gear hunting or at least stuck in a gear way too long when going up simple passes.
All 5th gen Runners have sequential mode. It's a step left from drive instead of having individual gear positions like before.
Yes I get that but the Limited doesn't come with other settable Logic modes.
I use manual gear selection nearly daily since I'm driving down steep hills on a regular basis. Small steep gravel roads. 20 mph is speeding. Rather use my trans than brakes. 1st gear is my friend. Guys following me I'm sure are wondering...WTF? Is his brake lights out in that brand new truck??!!
My '15 does the same and requires babysitting as OP said. Most posts I have seen about the FJ indicate it exhibits similar behaviour.
Since shifting causes lots of wear, I just put mine in S4 and wait for the top of the hill.
I hear that installing the supercharger gets rid of this issue.
Some sort of aftermarket programming change may work as well, but I am planning on staying stock so haven't explored that option.
There's no shift logic choice in any 5th gen 4runner.
Honestly thought this was a troll post when OP said steep hills in Kansas.
I drive mountain roads all the time and I like the shift points. locking and unlocking torque converter creates heat which reduces Tranny life so staying in 4 is like driving a stick. Also going down grades in lower gear keeps the speed in check and lessen the chance of brakes overheating.
My mistake, I was thinking there would be an MTS setting that could help but looks like this feature is only used at crawl speeds. I don't have MTS so didn't know till I looked at it closer after your comment.
Using your transmission as a brake going downhill actually causes your transmission to wear out faster.
How? The compression of the motor is doing much of the work and there's not much load on the transmission as the motor isn't creating any power (injectors are turned off under engine braking).
Engine braking is a preferred way to control downhill speed because if you ride the brakes for a long duration of time, you may be met with brake fade when you really need them.
It's a heavy, un-aerodynamic vehicle with a 4 liter V6. Regardless of the number of gears in the transmission, the transmission will always try to be in the highest gear on the highway for fuel economy. That means the RPM will be low, where the engine just isn't making enough power to handle grades, or headwinds, without downshifting to bring the RPM up to where the engine does make enough power to maintain speed.
