TRD Pro Clunk
alignment with front shock change due to clunk
When you got your new shocks installed and they removed the coils to do it, did you get an alignment?
Just wondering
My TRD Pro is going in on Tuesday and I am going to have them install a Toytec lift while they have it.
Sno Dawg
Just wondering
Sno Dawg
Not sure. I would think so since they are changing out the suspension. I would ask them to if not.
I too have had this "clunk" ever since the temperatures cooled off in the fall of 2015. I wouldn't really consider it a clunk, more so the front end just felt loose and rattled a lot, especially at low speeds. It just felt like an older SUV when the temperatures were below 50. I installed the toytec lift in November and saw no difference in the ride when the temperatures were below 50. I finally saw this post and the information about the TSB. Took it in to my dealer last week and they agreed to change the shocks. I took it back in yesterday to have the ordered shocks installed and mentioned my small lift that I would like to still have after the install of the new shocks. My service rep didn't give me an grief and they made the switch without any problems. The ride afterwards, WOW! What a difference that made. Now I feel like I'm riding a new car again with the cold temps. No loos rattling feeling up front at all. Thanks to those that posted the information on the TSB!
Your a lucky man to have such a good dealer to work with. I'm still waiting for the Temps to drop below 30F so I can reproduce the knock at the dealer. They know there is a tsb, but want to hear it for themselves first. Too bad this wasn't a recall. Hate going through the motions as it is an inconvenience.
Does anyone know if they are still using the old, 150 version of the shock on new 2017 TRD PROs? I get mine in a month and am wondering if I should request the new 160 shock before I pick it up.
Clunk resolved (philly)
Hey everyone. This is a problem I complained about since I first got the TRD PRO back in 2015.
Some people have the issue with the BILSTEINS clunking. Some don't. I complained about it to service for the first two times i took it in for regularly scheduled servicing. Not a single tech could "reproduce the clunk" so they weren't really willing to do anything about it.
I KNEW something was amiss and sure enough a TSB BULLETIN was issued. As soon as I let service know about the TSB, I showed the service manager the TSB BULLETIN, and while i was there I took him for a quick spin in the truck. Luckily it was cold out. Sure enough it clunked, and that was good enough for him.
They ordered the replacements for me and slapped them on and guess what...the clunk is GONE.
I'm running the 2 inch TOYTEC lift all around and i also have 33inch NITTO TRAIL GRAPPLERS. I've been hitting terrain and bumps that used to make the front suspension clunk, and now its completely gone.
If you have the clunk, the lift won't fix it. Anyone who says the lift fixed the clunk, I dont buy it. Its probably psychosomatic/wishful thinking. It is without question a design defect.
The BILSTEINS that were re-designed have the following part number
"PTR13 - 89160 - RF (or LF)"
the RF is for RIGHT FRONT and then the other should be LF for "LEFT FRONT".
I know some people who had the clunk and then straight up swapped their entire suspension for upgraded ICONS. Sure, thats awesome. But for me, the BILSTEINS are just fine for now. I've gone through some pretty intense terrain with them and for my purposes, I'm fine with them. I've been putting my money into other mods on the truck. If in the future I decide to upgrade the entire suspension system, then I may.
The BILSTEINS get shit on a lot in the off-road community, but whatever. It is what it is. They aren't ICONS....They certainly aren't KINGS...but if it aint broke, don't fix it.....They're fine for me as I'm sure they are fine for the lot of you out there.
To save this from being ENTIRELY long winded, that's my manifesto regarding the CLUNK. if you have the clunk, just google "TRD PRO 4RUNNER TSB" and you should be able to pull up the bulletin. Show it to your Service Manager at toyota. If they push back, give them hell and/or call corporate.
I'm an attorney, and I refuse to bear the burden of a design defect imposed on us by a third party who Toyota volitionally decided to partner with in the build of this model. It's TOYOTA's liability. They need to make this right for everyone.
Any questions, just ask.
D
All TRD pro 4runners having the 160 part number. You should be all set my man.
In another thread someone posted the rear remote reservoir was bumping against the wheel well. I still need to go check mine because I have the clunk too...
Well I got under the 4 Runner today and my driver side remote resi was actually touching the body. I got out my dremel and cutting wheel and took care of that.... clunk is now GONE!
BEFORE:
AFTER:
Why didn't you just slide it down in the mount?
Well, first, there is a ridge on the resi that is intended to be a "stop" so I would have had to force that raised ridge into the mount to move it down. Second, I wanted the resi to be farther from the ground and any projectiles that might hit it. So in the end, it was more work, but that is the way I wanted to do it.
so revisiting this... i dont think its suspension related... mine makes the "clunk" and my suspension is not oem. It sounds just like what the guy who posted the off road video on page 6/7?
Didnt someone say something regarding drive shaft grease or checking around page 20ish? I cant seem to find it again...
I also am having a clunk sound but only in the rear and only when cold outside . The thing is it gets very cold here ,the other day it was -41c. This is a brand new 2018 trd Pro still haven’t brought it to dealer , will be taking it in soon .
2016 Pro with clunk
I know this is an old thread, but I bought my 2016 Pro used and picked it up in October of 2017. It was already pretty chilly here in New Mexico so I heard the clunk as soon as I bought it. I immediately thought...oh great, I have blown out shocks...I drive over speed bumps on the way to work every day so I hear it all the time. Very annoying! After doing a little research and reading every post, I went to the dealer today and got both upgraded shocks on order. Thanks for the for everyones help and I will definitely spread the word. Will report back after the installation of the new parts. Hoping for a free alignment as well.
Update. My new struts were installed yesterday and they look a little beefed up compared to the old ones. Drove over some speed bumps this morning in 25 degree weather and smooth as butter. Bye bye clunk!
erinobr2000
