TRD Pro with 6112 coils (pics inside)
You are correct on the clips are set higher on the driver side to correct the lean but the lower spring seat itself is different on a Pro and must be reused. It might it have a small spacer on them. I'll be putting mine on Monday so I'll know for sure then.
Pics or it didn’t happen ;)
Over the weekend I had my Toytec spacer lift swapped out in favor for the 6112 coils. I gained about 1/2” lift in the front and have fallen in love with the feel of the truck now. It’s a more solid feel, much less nosedive under braking and less body roll through turns.
Pics to come!
Pics to come!
Thats awesome. Glad you were able to find some. Bilstein should just start selling them.
Has anybody else tried the FJPro springs? Following another Pro owners lead I tried the FJ springs on my truck. They are supposedly 14" x 600# vs the 13" 4Runner springs. I also added the Toytec TRD Pro lift (perch & top hat spacer) and 2" superflex rear springs.
Here's my post:
https://www.toyota-4runner.org/3302544-post1239.html
336236d1560029840-trd-pro-lift-question-img_20190608_111953022_hdr-jpg
Here's my post:
Yeah those are the same specs as the 6112 springs, and are probably both made by Eibach. I do like the fact that they are branded TRD and are red. Would have gone with those if I could have found a set at the time.
You can get them new from most dealers. I got mine from McGeorge in VA for around $200 for the pair.
But are they enough to provide 2-2.5" of lift over stock and still handle the added load of a winch and hybrid bumper?
I currently have icon 2.5s in front with a winch and sso bumper. I dropped 1/2 an inch with the added weight. The icon coils are softer than the 6112 coils so compared to a stock trail or sr5, i'd expect a 2 1/4 lift with that equipment. Compared to a pro, which is already lifted 1/2 an inch, you'd probably be looking at a 1 3/4" gain.
Here's my post:
I know I’m late to the follow up but your link isn’t working...
Pics to come!
Was that the full front Toytec from Pro lift? (thicker spring perch under the spring, and 1/4” spacer above the strut?
What size tires are you running, and would you mind measuring the height of the fender opening directly above the center of the wheel (from the ground)?
Anyone know where to find the 6112’s without the springs? I bought the TRD FJ Pro Kit last year when Toyota was clearing them out and would like to use those 14” TRD springs with the 4Runner shocks to raise the front more since I’ve settled.
Looking for some 600lb coils for my TRD pro suspension. Anyone have any leads?
I have a used set in great condition for $100. I was looking to pair them with 6112s but I couldn't find the shocks separately so I'm going to pickup a new coilover kit and sell these coils instead. These are the 14", 600# Bilsteins. There are a few scratches but very clean and no rust. PM if you are interested. Thanks, Jason
Picked up 6112 springs from @jrfordlandia and wheeler t13 for the rear.
Front is 23” from center of hub to fender, rear 23 3/8”. Drives great!
