Ultimate Scion Headunit (stereo) thread
i have this saved for reference, its supposedly from an e7007 JBL nav unit. i cannot confirm or deny if its correct...
if it is correct, it appears that plug could be for a CD changer?
Thanks for the reply @Yash2000 I appreciate it. I think you're right.
I did want to post on here a bit of info regarding the USB port.
I am running the PT546-00160 head unit and I had originally ordered the OEM USB harness. the thing was very expensive for what it was and then the idea that I had to modify it after that made me really annoyed.
I chose not to modify it. Instead I ordered this part of Amazon.
USB Audio Adapter Cable for Toyota Camry Venza Yaris
I finally received it today and am very pleased to announce that it worked perfectly and made it so there was no modifications needed.
I then took and used this part USB Panel Flush Mount Cable You can totally get away with the short one.
I then drilled a hole in the center console right next to the 12v plug (man that thing was hard to get to!) and put the flush mount adapter in.
Now everything functions like factory and Aha and USB work.
I figured I'd share this info because that adapter is WAY cheaper than the OEM one.
Good Luck everyone!
I'm just about ready for my install. I do have a question on the antenna adapter harness.
Does anybody know what the other attached harness is for? Here's a pic...
It is somewhat of a pass thru connector for one of the 2 main connectors.
Sent from my iPhone using Tapatalk Pro
Here is my T1819 in a 1997. When a get a better condition center console trim piece I'll make a pattern and do a better job.
All the parts etc...can be found on my "1997 SR5 build and repair thread"
Everything works. Holding the call button in until you hear the beep activates Siri to send or check messages, tell Siri to call someone etc.... My contact list is also loaded into the radio to select numbers manually.
So I liked the T1819 unit so much I installed one in my 2002 S Series Saturn. It needs a little more tweaking but it's in and works and sounds great.
I love this upgrade.
I did this upgrade back in 2014 and I love it. Follow the instructions and you can't screw it up.
Jig
I have a T10015 unit that I'm trying to bench test and I can't figure out which wires (I at least have the connectors and sections of wires attached) I need to connect to at least power the unit. I have found a few posts that allude to the pin outs or wire colors, but Photobucket has wrecked havoc on the threads. Do any of you have a wiring diagram for the T10015 unit that you can post or send to me?
I installed the T10015 about a year ago and I'm considering upgrading my speakers while still using the JBL amp. This poses a problem as there are few 2 ohm speaker options aside from the subwoofer.
Has anyone used the Scion headunit to power the speakers while using the Paco/Metra amp interface to continue to run the subwoofer?
I just replaced the stock sub with a Kicker 8" 2 ohm and I'm trying to avoid rewiring everything just to upgrade the speakers.
Hi all. Installed a T1028 in my 2006. Works great but keep getting this screen when I push the phone button. Any ideas what "loading consumption information " means. It never loads anything, just stays on that screen.
Sent from my HTC6545LVW using Tapatalk
Look for a owners manual for the car it came from........
So the cooling fan in the T1819 I put in my Saturn is going bad. Anyone ever need to replace a cooling fan yet?
So I put the Bluetooth mic in the 97 Puppy Hauler with the T1819, and paired her iPhone 6+ running IOS 11.3. It acts different than my iPhone 6+ running iOS 9. I refuse to update my iPhone to 11 until I absolutely have too.
It does suck the big one that there are not any firmware updates for the T1819. If there are I've not found any and I googled my brains out looking.
Bunkstaff
