Upgraded to Sport Edition interior trim, need help
CWccw
What did you do about the passenger side window and door lock switches? I can’t find schematics for specifically a 98 and 2002. All the FSM downloads are a general 4runner FSM.
The wiring is different from 1998 to 2002. If I remember Tommorrow. I can send photos of the power window circuits. :)
Sent from my SM-A505U using Tapatalk
I have a 98 and I got the drivers front master switch and passengers switch. Didn’t end up using it because the wiring was completely different. I got them because of the auto down for both front windows. You would of have to rewire the whole door to the dash to make them work, plus I didn’t have the EWD for the newer 99-02 trucks. I’m pretty sure you could add wires, but that would just be more time consuming.
honestly, I personally would stick with the chassis wiring and swap out the wiring in the door.
Here are the power lock circuits and it seems my power window 98 ewd is missing. :-(
Wow thanks! I might have to make a control board for this once I poke around inside the pass. side master switch I will know more.
Well we can compare it to the Toyota EWD I have.. :-)
Oops! Didn't see you posted one. It's getting a little confusing for me since there are two different threads for the same thing.
EDIT: Attached a 98 power window wiring diagram from Mitchell/ProDemand.
erinobr2000
