weeeee
Moving to a different roof rack? [MENTION=44305]weeeee[/MENTION]
Thinking about it if someone buys it
I'm riding on the 4th notch also.
They aligned ok. Caster was a little off because I tried to push it as high as possible (OEM is zero, I was shooting for roughly 2 degrees), but my toe and camber were spot on OEM specs. I think if I played with it a little more (or had caster set to 0) it would've been fine.
With a lift at 2.5", I'd recommend getting UCAs if you want to get better steering feedback because the increased caster will give you better straight line tracking and stability especially at highway speeds. I'm planning on getting UCAs soon.
Do you happen to have any more side profile pics you can post up?
I just received my Light Racing UCA's and am getting ready to install my lift. I'm debating between the 4th or 5th clip in the front.
I'll be running Bilstein 6112 in front with the 5160's in the rear along with the Toytec superflex springs. I've got the TRD wheels with the BFG KO2's 275/70/17 sizing. I'd like about a 1/2 to 3/4 inch rake in the rear but not quite sure where it will end up running in the 5th notch.
Have you thought about going to the 5th notch up front?
[MENTION=44305]weeeee[/MENTION] Good meeting you today and thanks for the cubby swap! Nice Pro man!
You should be fine with either one. Honestly if you're sticking with 275 I'd keep it on the 3rd or 4th notch- just my personal preference because of the wheel gap. I think [MENTION=103267]Saker[/MENTION] is running this setup and it looks awesome.
I haven't thought about cranking it all the way up yet. I get pretty good clearance with my 34s and the CV angles are pretty good so I'll probably leave it alone.
I'll post up some side profile pics when I get a chance.
Thanks man! Glad I could help you out (you probably helped me save some time too, lol). I'll catch you on the TW forums. Good luck with buyers for everything else!
Electrical/Solar Setup
I've been lagging pretty bad on updating this with some recent additions on account of getting this all ready quickly between work and a big camping trip that we took. I just finished up a big electrical project to keep up with my solar setup, fridge, and just to keep things clean for upcoming electrical mods.
First, I purchased a new Odyssey Group 31M to replace my regular starting battery. I opted to go with a single battery setup vs. a dual battery setup specifically to keep things simple. I also plan on supplementing this with a solar panel to keep juice flowing to the Indel-B fridge I just picked up.
Odyssey Group 31 Battery Install (in factory tray)
I started out by disconnecting the factory battery cables and removing the OEM battery
Since the new Odyssey is a bit larger, I needed to trim a portion from the OEM battery tray
Muscle the new Odyssey in- looks a little like this
Needed to purchase some Mil-Spec terminals and mated them to the factory terminals. Buttoned everything up.
DISCLAIMER:
When performing this mod, it is important to note that the OEM alternator is not rated high enough to charge the Odyssey to 100% charge. Battery lifespan may suffer if you do not fully charge the Odyssey on a Battery Tender or something similar every so often.
I recommend installing a NoCo 10 amp charger under the hood...pretty cheap, does a great job..
NOCO Genius GEN1 10 Amp 1-Bank Waterproof Smart On-Board Battery Charger https://www.amazon.com/dp/B003JSHQW0/ref=cm_sw_r_other_awd_CoG8wbFM1F45H
Looking good Victor! Glad to see things out of boxes and on your rig :bounce:
No Loss Valve Stem Caps
Ended up installing the easiest mod ever. If you air up/down frequently or hit the trails, these things are genius.
Source? These are gold!
Electrical/Solar Setup (continued)
Ok- after seeing this really want to see the rig. I have/am going to do all that you have done but my setup does not look anywhere as clean as yours.
