2016 4Runner SR5
Senior Member
Anyone here willing to donate their stock front door 6x9 speakers to me?
Guys
I am looking to replace my dash speakers to improve the sound quality. I removed the factory dash speakers and I see only two wires on the plug.
Most of the folks here mention there are four wires.
Can you please suggest how should I be wiring up my 3.5" speakers for the dash?
From the first Thread.
* The light green and pink wire are negative on both sides.
* The other two colors:
left side = violet + blue = positive
right side = yellow + blue = positive.
Mine are showing up today too.![]()
Has anyone re-verified these wire color codes? This seems wrong to me based on both the wiring diagram, as well as typical Toyota standard speaker wire practices.
I'm thinking it should be this, but just wanted to see what others have found:
Left:
Light Green + (to Dash Speaker)
Blue - (to Dash Speaker)
Pink + (to Door Speaker)
Violet - (to Door Speaker)
Right:
Pink + (to Dash Speaker)
Yellow - (to Dash Speaker)
Light Green + (to Door Speaker)
Blue - (to Door Speaker)
The negatives and positives are obviously tied together, and I'm thinking the above is correct. I guess the way to be sure would be to test speaker polarity with a 9v battery or something).
Does anyone have a lead on a 4-pin speaker adapter for these dash speakers? I'm certainly not going to hack up my vehicles harness, and I'd also rather not take apart the stock ones in the event I want to put them back in.
The only option I've seen is from Taco Tunes, but they're not cheap at $25. Too bad there isn't a metra or scosch option which would be about $5.
My other idea is to find someone with a set of stock Toyota speakers that have a wired 4 pin connector, and pay them to cut them off and mail to me. Seems like a number of Toyota speakers have harnesses like this, such as certain Camrys, Siennas, and even some of the JBLs in the 4Runner.
Has anyone tried to install the JBL GX302s without shaving the bottom of the speaker grills?
I installed GX302s and didn't shave my speaker grills. Did it a few weeks ago - details in my mod page.
I wasn't clear on a few details from you mod page. :doh:
Did you cut up and reuse the factory mounting bracket with an aftermarket wiring harness (if so which one),
or did you remove and reuse the factory connector as well?
While I am going to "upgrade" the factory 6x9 door speakers eventually, a low complexity install of dash speakers would seem a no-brainer...
Yeah I reused the factory mounting bracket and reused the factory connector as well.
I had to cut up a piece of the mounting bracket to fit.
And I removed the factory connector from the back of the old tweeters - just stuck on there with glue.
No aftermarket wiring harness.
A lot easier than I thought it was going to be.
Those pics are exactly what I did too.Hopefully these pics help...
Blue (factory) plug separates from factory speaker. Clear plastic mount separates from blue plug:
Looks like I'm going to order up the parts and give it a go...
My recent road trip to Zion may it pretty clear that an speaker upgrade is a necessary evil with the factory stereos.
Did you use bass blockers or did these come pre-installed?
I installed JBL GX302s this weekend, used the stock wiring harness as posted on page 11 (I think).
The sound difference is amazing!
If your on the fence, go for it, significant improvement!
Finally got my front harnesses in from Seicane on Ebay, and it looks like they'll work just fine. Total cost for both was $12 shipped, so quite a bit less than Tacotunes. Only drawback is waiting a week or two for shipping.
For those of you questioning whether or not to remove the factory capacitor, I think it should be done. Mine were 6.8 uF, which equates to a high pass frequency of about 5800hz on a 4ohm speaker. Some of the speakers people have been installing are closer to 2.5ohms, which would make it even worse at over 9000hz.
Also, the capacitors that are found on your new speakers are most likely just a high pass filter for the tweeter only, and do nothing to protect the woofer (there are a few exceptions here, such as the Infinity which has the crossover assembly wired in line with the speaker).
