I got the B-Pillars painted and reinstalled today. Not too difficult to remove but the bottom trim needs to also be removed to access the bolts for the handle and upper trim.
Prepping some parts for my suspension lift I'm hoping to install next week. I have forged aluminum upper control arms I put some matte clear coat on to help protect the finish of. Should be a pretty big update once installed!
Are those factory seat covers?
Did a flush style satoshi grille mod. The center trim bar that surrounds the Toyota emblem was breaking loose on one side.
I used some 1/8” mesh that my dad gave me. I think it’s the stuff used on security doors. I had to spend a bunch of time epoxying the tabs that the metal frame screw into. Almost everyone of them were broken. I used some of the trimmings from the mesh I used to try and reinforce them and used a 30 minute epoxy. It looks really good from a distance haha. Oh well. It was falling apart and I’d have to buy a new one at some point.
as a friend, I hope this is just temporary......:frisky:
I need to re do mine at some point...got some rock chips on my mesh part.
Sony XAV-AX4000 and Cupholders
Hi everyone, for me I've been looking into installing the Car Play Sony model above and Car Toys said the AX4000 will work w/ the 2005 4Runner even though Sony says only for 2010 up? Car Toys has modification kits so it will work but I was wondering if anyone else had installed this in their 4th Gen?
Also hoping someone has idea for a better cupholder -- the plastic adjustable arm doesn't work great for keeping the bottle and coffee that stable.
:confused:
Rear air spring delete and I still can't get over how much nicer it drives, it always felt unsettled and twitchy before, now its stable / smooth like a Cadillac and actually enjoyable to drive. New (but stock) front and rear coil springs + Bilstein 5100's.
What did you use for paint? It's all good bro, this is how you learn! If I ever make another one, it's going to be way better than the one I have now.
The surround was already Plasti-dipped which I plan on peeling off but I rattle canned over the whole thing with black satin finish instead of flat like the bumper is now. Once I get around to finishing the bumper with a center hoop I’ll paint the grille and bumper to have a similar finish which I really haven’t settled on.
If the repairs I made to the surround hold up I’ll most likely redo the whole thing with the CCG mesh and the deep satoshi look.
Bought a new set of Cooper AT3's to replace my 1 year old exploding Yokohama's. Maybe 5,000 miles on them, unsure of the cause.
I went to change the trans fluid today with cold engine.
I first removed the 5mm overflow plug and about 1.5 quarts came out. I expected none to come out since the engine was cold.
Then I removed the drain plug and another 1.8 quarts came out for a total of 3.3 quarts. This total sounds about right.
The 3.3 quarts total is a normal amount for a dump and fill so why did so much (1.5 quarts) come out when I first removed the overflow plug?
If it was overfilled, that would imply that, at correct level, only 1.8 quarts would have come out if I first removed the drain plug instead of the overflow plug.
Is 1.8 quarts the usual to come out for a drain and fill? Seems a bit low?
It must be running and at the correct temperature to check to fluid level, when not running a lot of the fluid is in the pan instead of circulating in the transmission.
About 3 1/2 quarts is about right when draining.
Here's a link to how to do all of this and correctly check the fluid level from Tacoma world, it's the same for our transmissions, there are several topics for this on this forum as well if you do a search for them.
How to Drain/Refill Automatic Transmission | Tacoma World
I made this same mistake - twice. As [MENTION=149207]AuSeeker[/MENTION] says, the transmission must be at operating temperature. The temp's not the only thing, having it warm also means the fluid is distributed through circulation throughout the transmission, not sitting in the pan. That's why that happened.
