sigbrown1297
Im not an alignment expert at all, but everything is in the green and pretty even on both sids.
Welcome!
Is that after alignment? from what I've ben seeing, they are not settling much if at all.
[MENTION=121322]'15WeissRhino[/MENTION] set it at the 1st setting and got 1.75" lift.
I think '15WeissRhino was set at the second groove ... (post #89)
yes, mine are on the second groove(0.5 inch average lift). I'm down from the 1.75" to about 1.5 inches above factory in the front now. Installed the 5160's on the rear a couple weeks ago and then had it aligned a second time last week. Gained about 1/8" in the rear with the new shocks. My alignment specs are in the green and almost exactly the same as 4runner714 specs. Really like the ride, very stable and absorb the big bumps nicely. Here are a couple photos:
On an unrated note, its amazing the difference on the amount of rusting on the underside depending on where you live. Just looking at your licks I could tell you were up north somewhere. Bought mine from a guy up in Maryland and I have some rust on my from the salt,brine.
looking good...wish I had gotten the front shock boots to match the rear.
also debating if i should get the billet mount. The supplied L-screws for the bracket broke off.
Yes, mine are on the second groove(0.5 inch average lift). I'm down from the 1.75" to about 1.5 inches above factory in the front now. Installed the 5160's on the rear a couple weeks ago and then had it aligned a second time last week. Gained about 1/8" in the rear with the new shocks. My alignment specs are in the green and almost exactly the same as 4Runner714 specs. Really like the ride, very stable and absorb the big bumps nicely. Here are a couple photos:
Thanks man! Gotta love the damn salt, bought it new, 21,000 miles later, it's absolutely disgusting how much undercarriage rust there is.........it's not even my daily driver!!!!!!! Think that's been covered in another thread :behindsofa:
Still contemplating moving from 4th to the 5th notch........decisions, decisions :noidea:
i just noticed that. How come ours didn't come with boots on the 6112? Different distributor? Didn't know that was an option. Oh well. Im sure as hell not taking it apart just to put those on.
The cheapest place i found the billet mounts was on autoplicity, where i got mine. I check my reservoir at every fill-up and its still holding tight.
Bilstein 11-176015 Reservoir Bracket Assembly | Autoplicity
get lift coils in the back.
