Ol' Ruby's frame off restomod thread.
2000 Toyota 4Runner SR-5 3.4L V6 4WD AT Sunfire Red Pearl
(with Topaz Metallic large fender flares)
5VZ-FE engine
A340F transmission
VF2A transfer case (j-shifter)
4.10 axle gear ratio
215,xxx miles.
Previous owner (owned from 2011-2020 (105k - 206k miles), work below done in 2018-2020):
- stock everything except 265/75/r16 highway tires.
- radiator
- valve cover gaskets
- timing belt
- battery
- water pump
- rear driveshaft
- catalytic converter (original was stolen!)
- oil change
- front and rear brakes serviced
- rear axle seals
- a few other things
I bought the truck December 2020 with about 206k miles. Came with original sticker and documents, along with about 11 years of service records.
2021 (~206000 - 208500 miles):
Chassis and Body:
- Full frame swap
- POR-15
- 3M Rust Fighter-I Internal Cavity Wax
Blasted/painted under floor pan
- Enlarged drain holes near the rear shock upper mounts
- New heat shielding along transmission tunnel
- Energy Suspension 8.4111R body mount bushings (instead of 8.4110R because the donor frame is '99, so position #2 body mounts are different)
- New rear chrome bumper sections (kept factory look)
- Running board delete (Limited-style Topaz Metallic running boards)
- Replaced missing
factory skid plates
- Replaced skid plate hardware with stainless steel (M8-1.25x25mm flange bolts)
- Front right valence panel plate (tow hook cover, PN 5392535020C0)
Upgraded recovery points with legokcen's
Front Shackle Bracket Set
Suspension and Steering:
OEM Lower Ball Joints and bolts (Left PN 4334039465, Right PN 4333039585, Bolts 8x PN 9008010066)
- Bilstein 5100 4Runner front shocks (PN 24-248730)
- Bilstein 5100 4Runner rear shocks (PN 24-249966)
- Old Man Emu 880 springs in front (2880)
- Old Man Emu 906 springs in back (2906, side-specific)
DuroBumps 3.5” extended, progressive bump stops
- OEM Steering gear assembly, includes assembled inner tie rods (PN 4425035042)
- Energy Suspension 8.10103R steering gear bushings
- OEM outer tie rods (Left PN 4504739215, Right PN 4504639335)
- OEM rear upper control arms (4x4-specific 2x PN 4871035040)
- Whiteline W53377A front lower control arm bushings
- Whiteline W63378 rear trailing arm bushings
- Whiteline W83374 panhard bar bushings
- Prothane 18-1115 red front sway bar bushings
- Moog K90681 greasable
front sway bar end links in rear, for extra length
- Moog K100127 greasable caster/camber adjusting kit
- Eimkeith's
panhard correction kit
- Alignment
Brakes:
- Extended braided stainless steel brake lines
- Parking brake bracket relocation
- ABS on-the-fly on/off switch (building on others' work, I'm planning a
one-switch solution)
Driveline:
TrakMotive TO8043ET Extended Articulation CV Axles
- Rebooted original OEM CV Axels as spares (2x PN 0443835062 (Outboard: black grease, Inboard: tan grease))
- Greased all zerk fittings (Lucas X-TRA Heavy Duty grease 10301 NLGI #2)
- Replaced front diff fill plug with Lexus PN 9034118060
- Replaced front diff drain plug with Lexus PN 9034124016
Wheels and Tires:
- Added a matching OEM wheel in stock spare location
- Spidertrax 1.25" hub-centric spacers
- 265/75/r16 BFG KO2 all-terrains (~32”) in 5-tire rotation (biggest fully-inflated tire size that
still fits in stock spare location)
Air and Fuel:
- Denso MAF sensor
- Fuel filter
- Cleaned throttle bottle
- Gas cap
ISR (intake silencer removal) (Airaid AIR-510-934 M.I.T., kept original tube/silencer untouched)
Vacuum hose replacement (Silicone Intakes VAC000308 blue thick-walled hoses)
Engine:
- Engine Oil Pressure Switch
- OEM cam seals (2x PN 9031138051, 2x PN 1118862010)
Cooling, Lubrication, Ventilation, Drainage:
- New radiator
- B&M 70264 SuperCooler external ATF cooler ran in series
- Magnefine 3/8" Magnetic Inline filter for ATF
- Transmission Filter (PN 3533060030)
- Tundra engine oil filter (higher capacity than 4Runner filter, PN 90915YZZD3)
- ARB breather extensions from transmission, transfer case, and rear diff (front diff already vents up high in engine bay)
- PCV valve
Extended AC Drain mod (
Here's the original write up)
- Full synthetic fluids drain & fill
- Shell Rotella T6 5w-40 Heavy Duty diesel engine oil
Electrical and Spark:
- Denso starter
- Starter relay
- Spark plugs
- Ignition coil boots
- Ignition wire set
- Repaired the
power steering idle-up switch (PN 9098011428, PN 8299812440)
Other:
Solenoid Assembly, Four Wheel Drive Control (PN 8544035040)
- Shift lock release button cover (4WD-specific PN 3355435050)
- Marlin Crawler MCTM-523 Heavy Duty Shifter Seat (Blue) for transfer case j-shifter (plus Gasket PN 3634535050 and Oil Deflector PN 3610835060)
- Replaced windshield washer nozzles with Honda PN 76810-TK8-A01
- Repaired pedal-side
throttle cable grommet
- Restored
center caps
- Windshield wipers
- XCAR Roof Rack Basket with extension
- 4.5 gallon RotoPaX
- Hella two-tone trumpet horns (HELLA 012010901)
- Fire extinguisher mounted under the front of the driver’s seat (Bracketeer UFEB1317/D)
DIY awning
Upgraded rear hatch struts and DIY nylon bushings (Strongarm 6815 Liftgate Supports, Hillman 880440 nylon spacers, Hillman 884573 nylon flat washers)
2022 (208600 miles)
Stubby antenna mod
Replaced both signal light assemblies (CarLights360 TO2530133 + TO2531133)
Next up:
- OEM HVAC Heater Control Valve (PN 8724035070)
- OEM Heater Hoses (PN 8724535670, 8724535680, 8724535730, 8724535770, 8724535451, 8724535461, 8724535690, 8724535710, 872453D090, 1577762020, 1626162060, 9955610300)
- OEM Engine Coolant Thermostat, with jiggle valve in the 6 o'clock position (Thermostat PN 9091603075, gasket PN 1632562010)
- Coolant system flush with Toyota Red (Genuine Toyota Fluid 00272-1LLAC-01 Long Life Coolant)
- TRD Radiator Cap (PN PTR040000003)
- Fan clutch (AISIN FCT-013 Engine Cooling Fan Clutch)
- Door checker/fixator repair
- Shifter bushings (4x PN 9038511003)
- Replace factory head unit with one that's not broken (backlit, tape deck, tune knob)
- Cat back exhaust repair/replacement (maybe Magnaflow Overland, Gibson, or Northern Stainless)
Down the road:
- Some body work (rear passenger dog leg rust, rocker panel gouges from running boards rubbing)
- Replace seals around rear hatch and driver's door
- Replace transmission mounts (and maybe engine mounts)
- Replace passenger headlight (small chip in glass)
- Auxiliary fuse and relay block with pre-wired loom through the firewall
- Fog lights in factory location
- Light bar behind grill
- Restored seats
- Toyota e-locker retrofit
- Rock sliders
- eimkeith's
lower link mount reinforcements
Big thank you to Jason from
OPT OFF ROAD and all the extremely knowledgable and helpful forum members here!!
