Mudflap DIY
spongerx
My solution to the major paint damage my truck incurred by having tires pushed outside the wheel wells.
After looking around for mud flaps I found 24x30 inch flaps at Murdoch's Ranch and Home Supple for $10 a piece. Only need one.
Measure to find the center line.
IMG_1419.jpg~original
Draw line and cut with Stanley knife.
IMG_1421.jpg~original
Figure out where you want it to hang. Use factory screw holes and mark the top screw. Drill a small pilot hole.
IMG_1422.jpg~original
Thread in top screw and get the flap into place.
IMG_1423.jpg~original
I used these screws from O'reillys Auto shop. They are longer than stock and you'll need a longer screw when using a thick flap and a washer. Longer screws will get you more bite. Stock screws next to new screws.
IMG_1439.jpg~original
Once the flap is hanging, mark the other screw holes and drill them out.
IMG_1424.jpg~original
Insert screws and washers and mount the flap in the wheel well. It may take some time to get a good fit. Keep working and drilling until to get the desired coverage.
IMG_1425.jpg~original
IMG_1429.jpg~original
Now that you have the correct screw hole distances, remove the flap and put it on top of the other flap and drill through for the same fit on the other side. Make sure to think about which edge of the flap you want facing out (factory edge).
IMG_1430.jpg~original
Get it ready for trimming. I measured about three inches from each hole and then rounded the line under the truck. Draw up your lines and cut.
IMG_1431.jpg~original
IMG_1432.jpg~original
Take the discarded piece and use it as a template for the other side. MAKE SURE YOU CUT OUT THE CORRECT SIDE!!!
IMG_1433.jpg~original
Install
IMG_1435.jpg~original
Enjoy the fruits of your labor.
IMG_1434.jpg~original
IMG_1437.jpg~original
IMG_1436.jpg~original
To really pull out all the stops, mimic the Jaos flaps where they meet the body, pop rivet some aluminum plate to the bottom on either side (punch some holes in it if it suits you), and tether the bottoms to the body to keep them out of the way. I was thinking about a project exactly like this, but it's still a bit out in my future. That's for blazing the trail!
TerryNap61
