DIY: Interior LED swap (cluster, HVAC, switches, window, *steering wheel)
Well crap, white is the color I needed. Guess ill stick with orange.
What Sparky said....try out the blue and white leds. I've got the blue in mine now and like it so far. I have the white ones also but haven't put them in due to their brown appearance in others' pictures.
Can you post a pic of the blue? And they're just plug and play no 12v mod needed?
here you go.
I like that one sparky. But I would have to do the digital mileage reader on the cluster that color too.
Not being a limited the white bleeds into it some, however still looks good, and like all pics it's better in person!
Sorry, missed your quote notification but looks like they've already posted a few pictures. It is just straight plug and play...no 12v mod required. I like the look of the blue even with my half-way done setup (haven't soldered any of the orange indicators or gauge lights yet, only plug-n-play LEDs for now). Honestly, planning to tackle my headlight retrofit before getting to that.
I ordered some from the warden_jp guy but still haven't received them and it's been about a week and a half. Did it take a while to get yours when you ordered them?
Sounds about right. I believe mine took right around 10 business days (~2 weeks).
LED interior swap
Is there anybody in the Georgia area that will do the interior LED swap? I have done the door, overhead, map light ect. mod but hesitant on working behind the dash.
I did the 12v mod for neo4 hp bulbs.
Pretty simple. Separate the positives on the LEDs. Solder wire to them. Run to a 12 volt source. I chose my accessory wire on my head units wiring harness. I used a male/female connector so I could remove it easier.
I originally tapped into the hvac wiring harness but wasn't sure which wire. (Always thought red or yellow was 12v) but I wasn't getting anything. So I moved to the wiring harness where I knew the 12v was coming from. I ended up getting the pos/neg backwards on the led like a dope. So when I had it wired it wasn't doing anything. Swapped the sides of the LEDs and viola.
In hindsight, a Multi meter would of probably helped.
How did you find the polarity of the LEDs? I tried using a multimeter and I also dont see any markings.
