All the belts replaced was with the oem Mitsubishi belt. 2nd and 3rd change
Aisin water pumps come with a metal gasket with a thin Brown silicon edge, please don't trust this and use gray silicone.
The timing belt that exploded was wet and brittle. Felt like rubber drenched in oil.
This is after 4 to 5 years of knowing the leak.
No matter what this engine is amazing.
Wow! I've been looking high and low for a 4th gen V8 because the price/performance on a 5th gen left me very unimpressed but this right here has me scared of buying a 4th gen V8.
I've even heard of a bad pulley causing a V8 to become trash.
I'm sure the chances of this happening are probably 1 in a 1000 but in my head that 1 will happen to me.
What was Toyota even thinking making this an interference engine?
Sent from my XT1650 using Tapatalk
OP, this may sound like a dumb question but what were the symptoms of the coolant leak? Were there visual signs of coolant on the front of the engine? Could you smell it? Or was coolant simply disappearing from the system necessitating refill?
4 years ago I saw a drip under the engine when i was changing the oil, then saw it coming from the covers behind the fan. then the second year I started topping off the coolant more frequently. 3rd, it over heated once...and now it started to leak from where the thermostat housing mounts to the pump. I was dumb and used Orange sealant. I heard Orange isnt as good as gray. by the 4th year, it was always a little wet around the steering rack and area. I knew I had to change it soon. then BAM...this happened. The belt was so brittle when I held it in my hands, Rubber powder build up was everywhere inside the covers, strands of belt everywhere as well.
This pic shows the buildup of Rubber
I'm glad your engine is ok. This is good tech info but I have some questions since it's hard to go out on a limb and say there is no interference when so much data suggests that it is an interfering eng. You had to physically rotate the drivers cam to line everything up? A true 180*? Maybe I'm blind but I see belt teeth throughout the whole belt. But something made it run like poop, so it jumped teeth? If it jumped teeth, this would immediately retard valve timing. This increases the piston to valve clearance for the intake valves and decreases the clearance for the exaust. Intake valves are always larger than exhaust valves so they are at the most risk. Say you jumped 180 on the driver cam, this will retard the cam, and cause all your symptoms, but since the cam is retarded, there is more intake valve clearance. This only works out in your favor if the cam didn't spin 360 or more. And you may have kissed valve to piston anyways. Hot steel valves vs hot aluminum can put a good mark in the piston but still leave the valves and piston relatively ok, it all depends on how much interference there is. You can check by scoping through the spark plug hole. Some people get lucky when a belt snaps in half because all the valves stop and aren't at max lift. Let's fully diagnose this before we call this 2uz-fe interference engine a myth.
Not following your logic on the intake valves having more clearance. The two cams on each head are geared together driven by the one cogged pulley. Clearance or lift will not change.
I would say it doesn't disprove what Toyota themselves state. But it does muddy the waters a bit because it could be more realistic that the VVTi vehicles have a tighter combustion chamber. It's hard to say, I've seen a 2UZ-FE that blew a belt and bent valves and I currently have a 2000 LC100 in my stall that broke a belt (non-Toyota) that we're gonna try throwing a belt on and seeing how the compression looks.
This reminds me of the whole nebulous and still unverified (one way or the other) "Japanese 2UZ rods are stronger than US ones." For every "I got lucky and it didn't total my motor" there's "well the belt broke and now I'm out an engine." Even modern "non-interference" engines with chains have such tight clearances that if a chain did break while at a good enough speed it could conceivably impact a piston (actually have seen that on a non-Toyota engine that was supposedly non-interference)
I would say there's no reason to be afraid of owning a V8, if your doing your maintenance properly with quality parts, you're probably never going to break a belt.
Also it's Mistuboshi who makes our belts, not Mistubishi (I made the same mistake for a while until someone corrected me and I actually read the belt label properly. lol)
Only a guess but somewhat educated. I think an engine subject to the momentum "shock" of breaking a timing belt at high RPM might be likely to experience some valve float due to the sudden shift in load. Could help explain the some do-some don't.So just for those of you curious on the outcome. Threw a new Timing Belt and Water Pump on that LC100 with 170k on it. She's choochin' pretty skookum so far. Rather surprised, thought she was going to have a bent valve or something, but she checked okay when we did the compression check and she ran good once I got her back together today. Customer got lucky.
Anyways, the main take-away here is that Toyota specifies that the 2UZ-FE is an Interference Motor. That's it, there's no questioning it, no doubt, no nebulous delineation. The designer, builder, and manufacturer of the engine has specified that the engine is an interference design. They would not waste the effort to plaster that warning for almost 2 decades in every FSM, training manual, ect. unless they believed it to be a potential issue.
Now, notice I italicized "potential". It seems that the 2UZ-FE is not as grenade-prone as say Honda engines are when a belt breaks, but rather there's a potential for the valves to nick the pistons when it's free-running without a belt to time things. I'm guessing that means that somewhere in the valve travel there's a point where they could possibly smack a piston if it were out of time, which was more than enough for Toyota to label it an interference motor.
So, bottom line. I you have a broken belt and she turns over and doesn't sound like something's done broken. Throw a belt on there and do a compression check to see if you got lucky.![]()
An interesting regaled aside, according to Toyota records my 04 was towed in at about 40k for a non- start condition. Turned out the belt jumped a tooth. 13+ years old, 3rd owner, 195k, 3rd belt, runs great no issues.
I do however have to at some point address the spark plugs that have been in for "who knows how long" and I'm thinking the next belt (about 30k from now) would be a good time. Anyone know the signs of weak plugs on these engines?
Bob, valve floats comes from when valve springs aren't strong enough to close the valve on time. Happens at high rpm where the cam lobe starts dropping off but the spring can't shut it properly because rpm is so fast. Can also happen to aftermarket cams where the cam lobe lift and ramp is very aggressive and the springs can't handle the job. I doubt an overhead cam engine with a redline of 5k can float the valves, but I suppose it's possible if the springs are weak.
Engines that sit for long periods of time without running (many years) can weaken the springs that are being held open. This is why I cringe when I see a FB post about a barn-find that has been sitting for 30 years, they "service it" and fire it up and think everything is ok. Springs can break in those cases. A lot of hot rod guys, during their winterize checklist, take the rockers off to close all the valves after fogging the engine with wd-40. Just so some springs don't sit open and the cylinders remain oiled with no exposure to atmosphere.
As far as spark plugs go, as the electrodes erode, the gap becomes larger. It's harder for spark to jump this gap when rpm is high (less spark energy) and when cylinder pressures are at their maximum (high load/full throttle/towing/etc). So you'll likely see a misfire, worst case.
Like blackworks ponders in the post below yours. Or maybe? Think of it like a world class bicycle sprinter coming I clipped at full power. One of the worst solo crashes a rider can have. Inertia. Also no more compression holding some valves back. I know what valve float is but thanks anyway. There are more than one or two causes. Can you imagine the forces produced inside one of these engines at full throttle at maybe 5k rpm? In the old days, before interference engines. it was easy to push a valve throung a piston by missing a power shift. Yes foot off the gas but when you missed a gear and let out the clutch things could and too often on the track would spin with a bit more energy or thrust then when under load valve into piston nearly new heavy duty valve springs: bang.
