FYI, here is the best video I found for removing the fan. From reading about it, I was confused about which bolts to remove.
https://www.youtube.com/watch?v=yAyVisRT_gs
I couldn't find a suitable fan wrench, but I was able to do it using two wrenches pushing on one and turning the other. A rubber doorstop was not useful for holding the pulley because Home Depot only sells mostly hollow doorstops. Maybe a solid one would work.
Here are some of the tools I needed:
12mm box wrench for fan clutch bolts
14mm box wrench for bottom alternator bolt and top front AC compressor bolt (who thought it was a good idea to put rigid AC lines in front of these bolts?)
Two 3 inch extensions, two 6 inch extensions, and one universal joint
Deep sockets 12mm, 14mm
Regular sockets 10mm, 12mm, 14mm
Deep or regular socket 22mm
13mm box wrench or socket if you need to replace the radiator
Various pliers for hose clips
Normal torque wrench
Torque wrench for 181 ft-lb crank pulley bolt
Flathead screwdriver for prying, scraping, pushing hoses
Vise grips for the stuck phillips screw on the AC bracket. Manual or powered impact could work too.
Large hammer for loosening things
10mm hex wrench for the timing belt tensioner. 10mm hex bit for torquing it.
scotchbrite to scrub corrosion off the water pump gasket surface
Buckets and tubing to catch coolant
Cheater bar to put over wrench to break things loose.
I made my own crank pulley holding tool from some steel bar stock and some metric bolts (here are various ideas
https://www.tacomaworld.com/threads/homemade-crank-pulley-tool.140646/), but the bolts bent and damaged the threads in the pulley. I'd either buy the right tool for it, such as
https://www.amazon.com/Schley-SCH64300-Toyota-Harmonic-Holding/dp/B0051XDBBG or use an old drive belt.
To use an old drive belt:
- Fold the belt rib side out
- Wrap the belt around the crank pulley so that it grips the pulley as you turn the nut in the desired direction (loosen or tighten)
- Loop the other end of the belt around something solid. If there's nothing in the way the upper suspension arm mounts work great. The fan pulley bracket is good too.
- As you turn the nut the belt will tighten around itself and grip the pulley.
Note: this creases the belt, so don't try to reuse it after.
