3rd Gen T4R DIY Maintenance, Repair and Modification Videos
timmy, i wanted to thank you for the TBU vid. well, lots of them, haha, but that one helped me tremendously. got the job done with a minimum of carnage, and now the 4R doesn't thrash around in the lane on a hard brake. just re-bled it this afternoon since it seemed a little soft, still.
You're welcome. Your brake pedal is going to feel a little softer because the Tundra calipers are bigger and require a higher volume of brake fluid. But, your braking should be overall stronger even though your pedal feels different. It just takes some time to get use to.
wow. that's daunting. at present, it's exponentially more work than a 3.0 --> 3.4 swap, which has now become fairly boilerplate. thanks for making and posting that vid.
You're welcome. Your brake pedal is going to feel a little softer because the Tundra calipers are bigger and require a higher volume of brake fluid. -snip-
that's really interesting. i just started surfing posts about peoples' various MC and booster upgrades. all new things i never have to think about with my '95 PU :D thanks again
Clutch Replacment
These videos show you how to do a clutch job on your V6 5speed 3rd Gen.
Hey guys, don't know how to ask this so I'll do my best.
Brother in law is installing the aircabinman timing belt kit this weekend. I've had a radiator/upper lower hoses/thermostat/coolant sitting in the garage waiting to go in.
My dilemma is what to do about the radiator? Should I flush and replace it before hand, flush only and replace radiator after? For whatever reason he says he can't recover the coolant and reuse it if I were to change the coolant out beforehand.
Seems to me like either way, I'll be out an extra 50 on coolant. I thought about flushing it, replacing radiator items and running it on distilled water. It will only be for 1 day, but reading online it says distilled water isn't good either on its own. Any thoughts?
He'll be doing the work on his day off at the dealer he works at and I'm already getting a killer deal on labor and don't feel like adding something like a radiator to his list of things to do.
Thanks.
Sent from my SM-G965U using Tapatalk
[MENTION=65101]BrianSD_42[/MENTION] gave me an idea when he started a thread, "List of 3rd Gen Builds with the most DIY help/advice". [MENTION=102606]infamousRNR[/MENTION] (aka Sean) and I (aka Timmy the Toolman) have done a fair amount of DIY videos now and I was thinking it would be helpful to put them all in one place, so if somebody finds this thread, they'll find every DIY video we've done to date and maybe one of them will help them out.
So, sit back, relax and enjoy some "Toyota Time" with Timmy the Toolman and Sean.
Edit 04/19/16 - Other members have expressed interest in posting their DIY videos on this thread as well and I say go right ahead.
Edit 05/06/16 - It was suggested that a Table of Contents listed in the first post with permalinks to the videos would be beneficial to people visiting this thread and looking for a particular video without having to browse through all the pages. So, here it goes:
TABLE OF CONTENTS
1) Sleeve Yoke Binding Fix (aka Slip Yoke Binding Fix) Video 1 of 2
3rd Gen Toyota 4Runner DIY Videos - Toyota 4Runner Forum - Largest 4Runner Forum
2) Video 2 of 2 to solve your Sleeve Yoke Binding
3) 3.4 Liter V6 5VZ-FE Valve Cover Gaskets How-To Video
4) Steering Rack and Front Sway Bar Bushing Replacement Video Tutorial
5) Instrument Panel Light Bulb Replacement
6) Restoring Color to Your Plastic Trim
http://www.toyota-4runner.org/3rd-gen-t4rs/217550-3rd-gen-toyota-4runner-diy-videos.html#post2323347
7) Low-Tech Power Steering Fluid Replacement
http://www.toyota-4runner.org/3rd-gen-t4rs/217550-3rd-gen-toyota-4runner-diy-videos.html#post2323348
8) Sea Foam Engine Treatment
http://www.toyota-4runner.org/3rd-gen-t4rs/217550-3rd-gen-toyota-4runner-diy-videos.html#post2323349
9) Lower Ball Joint Replacement Tutorial
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-2.html#post2329586
10) Tranny Pan Gasket and Drive Belt Replacement Videos by [MENTION=48234]stir_fry_boy[/MENTION]
(See Video #70 for another video on replacing the Automatic Transmission Filter by Timmy the Toolman and Sean)
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-2.html#post2337128
11) Tranny Cooler Install with Radiator and Thermostat Replacement
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-2.html#post2344949
12) CV Axle Replacement Video by [MENTION=48234]stir_fry_boy[/MENTION]
(There's also another CV Axle video w/ Reboot Procedure at #27)
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-2.html#post2348519
13) Lower Balljoint Inspection
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-2.html#post2351611
14) Rear Coil Spring Replacement and Rear Shock Bushing Replacement
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-3.html#post2352671
15) Starter Removal and Solenoid Repair
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-3.html#post2352954
16) Adjusting drum brakes so you can get the drums off the axle
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-3.html#post2393975
17) 30,000 Mile Service (Fluid Changes, Driveshaft Greasing, Brake Insp., etc)
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-3.html#post2406402
18) Suspension Lift (Coils and Shock Replacement)
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-3.html#post2419099
19) Brake Fluid Flush/Bleed
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-4.html#post2425758
20) Fan Clutch Test and Replacement
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-4.html#post2425759
21) Automatic Transmission Fluid Flush
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-4.html#post2456925
22) Diagnosing High Coolant Temps
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-4.html#post2457202
23) Alternator Brushes Replacement
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-4.html#post2458869
24) AC Condenser Cleaning
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-4.html#post2461564
25) Rear Differential Extended Breather Mod
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-5.html#post2496258
26) Dash Cam Install
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-5.html#post2500796
27) CV Axle Reboot w/ Extended Boot Mod and Replacement
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-7.html#post2525143
28) Lower Control Arm Bushing Replacement Part 1 (See #72 for Part 2 of this repair)
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-8.html#post2534670
29) Front Driveshaft U-Joint Replacement Video by [MENTION=48234]stir_fry_boy[/MENTION]
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-9.html#post2538004
30) Drive Belt Replacement (Power Steering, AC, and Alternator)
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-9.html#post2538317
31) Tundra Brake Upgrade aka TBU
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-12.html#post2551280
32) 3rd Gen Toyota Tacoma Whip Mod Video by [MENTION=122062]sambishop[/MENTION]
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-14.html#post2573999
33) Toytec 2" Body Lift Installation
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-15.html#post2576976
34) ToyTec Boss Complete Suspension Lift Installation
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-15.html#post2592808
35) Overdrive Off = Transmission Temp Drop
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-16.html#post2595599
36) Rear Sway Bar Bushing Replacement Video by [MENTION=122062]sambishop[/MENTION]
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-16.html#post2603536
37) Front Differential Axle Seal Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-16.html#post2603920
38) Power Steering Rack Bushing Replacement (Also See #4 on List for Similar Video) Video by [MENTION=122062]sambishop[/MENTION]
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-16.html#post2612883
39) Steering Rack Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-16.html#post2617174
40) Sammy's Comedic Automatic Transmission Fluid Exchange (Also See #21 on List for Similar Video - just with no comedy or profanity) Video by [MENTION=122062]sambishop[/MENTION]
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-16.html#post2632637
41) Bilstein 6112 Coilover Install - Video by [MENTION=122062]sambishop[/MENTION]
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-17.html#post2641994
42) Cooling System Flush
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-17.html#post2652394
43) How To Fit Bigger Tires On Your Truck/SUV Video by [MENTION=122062]sambishop[/MENTION]
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-18.html#post2653628
44) 3rd Member Swap
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-18.html#post2654954
45) Rear Axle Seal/Bearing Replacement (ABS and Non-ABS Rearends)
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-20.html#post2676823
46) Manual Hub Conversion
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-21.html#post2679984
47) Automatic Transmission Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-22.html#post2705015
48) Wheel Lug Nut Stud Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-22.html#post2706410
49) Steering Rack Guide Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-23.html#post2708565
50) Toyota 3.4 Rear Main Seal Replacement Video by [MENTION=122062]sambishop[/MENTION]
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-23.html#post2709122
51) Toyota 3RZ Header Install
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-24.html#post2724566
52) Front Differential Replacement For another video for this job, check out #115
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-25.html#post2763608
53) Transmission and Engine Mount Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-25.html#post2765814
54) Air Conditioning Recharge
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-25.html#post2776586
55) Fuel Filter Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-25.html#post2782415
56) Drum Brake Shoe Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-26.html#post2797480
57) Starter Replacement (Also see #15 on the list for a similar Starter Repair Video) Video by [MENTION=122062]sambishop[/MENTION]
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-26.html#post2806929
58) Toyota Timing Belt Replacement (PART 1) for 3.4L V6 5VZ-FE
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-27.html#post2831265
59) Toyota Timing Belt Replacement (PART 2) for 3.4L V6 5VZ-FE
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-27.html#post2844795
60)V8 Swap (5VZ-FE 3.4L V6 to 2UZ-FE 4.7L V8)
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-27.html#post2849655
61) Sunroof Drain Cleaning
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-28.html#post2851552
62) Rear Lower Control Arm Bushing Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-28.html#post2852260
63) ARB Bumper Install
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-28.html#post2873937
64) 5VZ-FE 3.4L V6 Compression Test
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-29.html#post2876106
65) Power Steering Flush and Reservoir Cleaning
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-29.html#post2881368
66) Steering Wheel Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-30.html#post2891855
67) Headliner Removal and Sunroof Leak Fix
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-30.html#post2892743
68) Toyota 5VZ-FE 3.4 Liter V6 Supercharger Installation
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-30.html#post2904621
69) Supercharger Nose Cone Oil Plug Mod Video by [MENTION=122062]sambishop[/MENTION]
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-31.html#post2906288
70) Automatic Transmission Filter Replacement (A340F)
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-32.html#post2920560
71) Fuel Sending Unit Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-32.html#post2924278
72) Lower Control Arm Bushing Replacement Part 2
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-32.html#post2949883
73) Automatic Transmission Temperature Gauge Installation
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-32.html#post2953940
74) CBI Dual Swing Arm Rear Bumper Install (Part 1)
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-33.html#post2960331
75) CBI Dual Swing Arm Rear Bumper Intall (Part 2)
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-33.html#post2970457
76) Rear Upper Control Arm Bushing Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-33.html#post2970821
77) Front Upper Control Arm Bushing Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-33.html#post2971841
78) CBI Weld-on Rock Slider Install
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-33.html#post2992751
79) CBI Hybrid Front Bumper Install
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-33.html#post2992752
80) Panhard Correction Kit (PCK) Install - Brackets made by [MENTION=28464]eimkeith[/MENTION]
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-33.html#post3001350
81) CBI Skid Plate Install
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-34.html#post3003530
82) Lil' Skip's Offroad Gas Tank Skid Plate Install
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-34.html#post3005617
83) Stripped Differential Drain Plug Removal
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-34.html#post3008720
84) O2 Sensor Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-34.html#post3008723
85) E-Locker Swap
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-34.html#post3017345
86) Warn M8000 Winch Install on a CBI Front Hybrid Bumper
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-34.html#post3027599
87) BudBuilt Rear Differential Skid Plate Installation
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-35.html#post3041148
88) Manual Hub Swap Part 2 - A.D.D. Hub Bearing Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-35.html#post3048117
89) Lotus RCAMS (Rear Control Arm Mount Skid) Installation
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-35.html#post3096549
90) Engine Misfire Diagnosis & Fuel Injector Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-35.html#post3124082
91) Inner and Outer Tie Rod Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-35.html#post3140173
92) E-Locker Bench Test
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-36.html#post3141426
93) Durobump Bump Stop Installation
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-37.html#post3162308
94) Upper Balljoint Replacement Video
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-37.html#post3169433
95) Phone Mounting Options
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-37.html#post3180028
96) ECGS Clamshell CV Axle Bushing install
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-38.html#post3190504
97) Steering Play Fix
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-38.html#post3190506
98) U-Joint Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-38.html#post3192345
99) ECU Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-38.html#post3193944
100) Hood Lift Strut Mod
https://www.toyota-4runner.org/3rd-...toyota-4runner-diy-videos-38.html#post3194957
101) Center Console Mod - Cup Holder Mod for 96-98 Toyota 4Runner's
https://www.toyota-4runner.org/3210521-post570.html
102) 4Lo and Your Automatic Transmission
https://www.toyota-4runner.org/3218324-post572.html
103) Toyota Rear Axle Seal/Bearing Replacement (Part 2) by jearred.foruria
url]https://www.toyota-4runner.org/3230931-post577.html[/url]
104) Reat Hatch Strut Replacement
https://www.toyota-4runner.org/3237696-post587.html
105) Savage Off-Road Front Hybrid Winch Bumper Install
https://www.toyota-4runner.org/3237697-post588.html
106) Savage Off-Road Hybrid Rear Bumper Install Part 1
https://www.toyota-4runner.org/3247310-post590.html
107) Savage Off-Road Hybrid Rear Bumper Install Part 2
https://www.toyota-4runner.org/3247315-post591.html
108) Toyota 3RZ-FE Valve Adjustment
https://www.toyota-4runner.org/3247320-post592.html
109) Engine Cylinder Leak Down Test
https://www.toyota-4runner.org/3256936-post593.html
110) Transfer Case Output Shaft Seal Replacement
https://www.toyota-4runner.org/3264335-post603.html
111) Engine Ignition Timing Check / Timing Belt Inspection
https://www.toyota-4runner.org/3288673-post631.html
112) Coastal Offroad High Clearance Front Bumper Build Video by [MENTION=407898]jearred.foruria[/MENTION]
https://www.toyota-4runner.org/3330217-post677.html
113) OME 891 Rear Coil Install Video by [MENTION=407898]jearred.foruria[/MENTION]
https://www.toyota-4runner.org/3330220-post678.html
114) How to paint your 3rd Gen Wheels Video by [MENTION=407898]jearred.foruria[/MENTION]
https://www.toyota-4runner.org/3330223-post679.html
115) East Coast Gear Supply Front Diff install Video [email protected] For another video for this job, check out #52
https://www.toyota-4runner.org/3347174-post692.html
116) Clutch Replacement
https://www.toyota-4runner.org/3375555-post725.html
woah, super useful, thank you!
Thanks.
I would flush the cooling system before doing the timing belt/water pump. Flush it with distilled water. Walmart has it for $1/gal.
There's really no reason not to be able to recover coolant. There's a drain on the bottom left (driver side) of the radiator. I had to replace my thermostat after I did my timing belt/water pump/radiator replacement and just caught my good coolant in a clean 5 gallon jug. You'll lose some coolant but not much. Make sure to use a spill free funnel to purge the air from your cooling system afterwards.
After Driving or idling for a bit, there is an annoying vibration sound and feeling coming from around the gas tank, although I have not 100% confirmed the noise to be from the tank. But I can feel it in the floor board on the driver side where the fuel lines run underneath, and when I touch them I can feel the vibration in them. Fuel pump is brand new, as well as fuel filter. I have also checked the fuel lines from tank all the way to the engine to make sure the aren’t vibrating against each other. My next thing to check is the purge valve solenoid and canister. I Also have ran seafoam through. Any ideas? It’s a sound just loud enough to drive you crazy
Sorry for the lengthy post, just wanted to make sure I covered everything I’ve tried up until this point. Btw it’s the 3.4L
I went ahead and flushed it with distilled water. I left distilled water in there, it will only be drive 30 miles downhill to his house, and another 15 miles to the dealership. I figured if he really couldn't recover the coolant, at least there will be a clean slate for him to pour the new stuff in.
Hard to say. So, it's making noise not moving, just sitting there idling?
Disk Brake Service
Here's a video showing you how to do a disk brake service - replacing the pads and resurfacing the rotors.
Yes, it will do it while driving as well but I only partially feel it vibration then because the car is up to speed. But sitting at an idle it’s very noticeable in the driver seat. It’s a hard noise to describe
I wonder if it could be a cracked flex plate. Record a short video clip of the sound so we can hear what you're hearing.
at the end of my rope/ a real problem
hi im trying to get this code to go away P0171 i have replaced the o2 sencers up stream and down i have replaced gaskets, hoses,well everything but the code wont go away. now when i start her she reves between the 1 and 2, and when im driving she runs beautefull. so what could it be???? please if you have any ideas WE NEED HELP........
Check the MAF sensor (Mass Air Flow).
P0171 & P0172.pdf - Google Drive
Yeah, what he said. Just pull the MAF and spray the wire contact inside the sensor with Mass Air Flow Sensor Cleaner: Amazon.com: CRC 05110 Mass Air Flow Sensor Cleaner - 11 Wt Oz.: Sports & Outdoors Be careful not to damage the wire with the tip of nozzle sprayer hose. You're not spraying the thing that has a yellow/gold coating. You're spraying the tiny wire inside the sensor. When it gets dirty, it doesn't correctly sense how much air is actually coming in so it thinks more air is needed and your fuel ratio gets "lean" as a result. Once you clean it, the MAF will accurately read the amount of air coming in and will fix in the improper air/fuel mixture ratio.
You can get MAF cleaner online with the link I provided or just visit your local auto parts store.
charlesz
